Is anyone running this combination? Im going to measure properly later, but I think the interrupted seat tube is going to leave too much seat post showing for me.
I think if any post is going to work then it's going to be a Reverb, possibly with the Connectamajig removed.
Just measure it all an drop a non dropper in to see how far it goes down?
I have a 150mm reverb stealth on my Large v4 and it's possible to fully insert it into the frame.
How about considering the bikeyoke revive? The 160 dropper has quite a short overall length.
Thanks Finkill - yep, Commencal fit a 150 as standard on large, but I think it will be tight in a medium. The suspension pivot isnt a complete block in the tube (obviously - it's Stealth....) but I had issues showing a 125mm post into a small Meta frame, it's easy to crush / kink the hose and cause issues with the post's activation. That's also why I would remove the Connectamajig I think.
The Bikeyoke one looks interesting - I assume "non-servicable" is to be read as a positive?! But there are some good offers on B1 Reverbs with the new remote around at the moment too.
