Command Seatpost Se...
[Closed] Command Seatpost Servicing - Best grease to use?
4 Users
Need to service a Command dropper post and watched a vid that suggests using slick honey grease.
I've got a big bottle of Fox fluid and some Phil Wood waterproof grease.
Reckon a bit of these will be a good substitute?
Posted : 24/02/2016 1:38 pm
should be fine. i use the proper green shimano stuff on my rsp plummet...gives it a really smooth action
Posted : 24/02/2016 2:19 pm
Can you post a link to the service vid?
Posted : 24/02/2016 2:46 pm
[url=
Post Service Vid[/url]
Thanks all, video linky above. To be fair its a basic maintenance video not a full service video if thats what you're after.
Posted : 24/02/2016 3:00 pm
I just use normal bearing grease, usually the white lithium stuff. Can't see that it makes much difference. I wouldn't use fox float fluid, though.
Posted : 24/02/2016 3:03 pm
Thanks. That grease he uses looks about the same as KS grease which you can get from Stif if you can't find anything else suitable.
Posted : 24/02/2016 3:08 pm
