Command dropper
[Closed] Command dropper
4 Users
Had any body run a 30.9 command dropper with a shim to fit a 31.6? If you have how has it run? Cheers
Posted : 03/03/2013 2:05 pm
I've run others (GD and a cheapo german KS copy) with a shim from 30.9 to 31.6. It works fine. The only thing I've noticed is that it creaks a lot if you get dirt between the shim and frame.
Posted : 03/03/2013 2:18 pm
I've done it. Used it with a shim for about a year with no problems.
Posted : 03/03/2013 2:40 pm
Posted : 03/03/2013 4:53 pm
yip so did i.. used a USE shim.. recently changed frame so selling one for a fiver including postage..
Posted : 03/03/2013 5:47 pm
