Collecting a used b...
[Closed] Collecting a used bike and wanting to ride it straight away
23 Users
So I'm collecting a 2 year old full susser that is (appartently) in good nick. Given the drive - I am tempted to stop off at a trail centre on the return and give try it out for a few hours.
Parts wise - apart from my regular saddle - what parts / backup etc / do you think I need to bring with me to cover the inevitable niggles? I'll have my multitool, co2, tube: but what's likely to give me gip?
Posted : 01/09/2019 10:25 pm
Shock pump
Posted : 01/09/2019 10:27 pm
Cheers! That's so obvious I hadn't even considered it. Which prompts me to add to list :cable ties.
Posted : 01/09/2019 10:31 pm
Pedals, probably
Posted : 01/09/2019 10:56 pm
Cheers: that's a good point: the listing includes flats, but some folk just presume a sale doesn't include pedals.
Posted : 01/09/2019 10:59 pm
I'd take some proper allen keys/torx for the set up of brake/shift levers rather than just a multitool.
Trackpump, plus the above, shockpump and pedals.
Oh and chain lube.
Posted : 01/09/2019 11:01 pm
New grips. Last owner might have touched his widgie and not washed his hands.
Posted : 01/09/2019 11:02 pm
Brake pads. Tube. Toray 700 weave. Resin. Acetylene torch. Brazing tank. Anodising tanks. Bread maker.
Posted : 01/09/2019 11:08 pm
Spare bike?
Posted : 01/09/2019 11:11 pm
Take it home first and give it a once over. Previous owner may have neglected it and it may be dangerous. Check all the main bolts like bars and stem etc and the quick releases.
Posted : 01/09/2019 11:13 pm
I can see your thinking, if your travelling to pick the bike up you might aswell make the most of the journey.
I'm always very wary when buying a used bike and usually do a loop local to home to check all is well. If you do a trail centre on the way home just make sure you are well tooled up. If the centre has a skills loop near the carpark I'd spend 30 minutes in there just to check the bike is ok.
Posted : 01/09/2019 11:25 pm
I had this urge once and it led to me riding my new BMX into the back of my own car
Posted : 01/09/2019 11:30 pm
I recently caught the train to collect a 10yrs-old used hardtail then rode it 35 miles home. Took water, wallet and my keys in a Lobo bag, along with pump, multitool and puncture kit.
Can often tell quite a bit about any likely bike issues by talking to the seller
Posted : 02/09/2019 2:18 am
Just because you don't really know what you are getting until you actually get your hands on it, I think I'd probably be taking my "main" toolbox, and a workstand, so that I can do a full check on everything in the carpark before I set off.
I assume you are collecting by car, so why not just throw it in?
Posted : 02/09/2019 3:23 am
Wow ... i'd just wing it. That way even if it all turns to shnitzel at least you had an adventure.
... maybe a helmet.
Posted : 02/09/2019 7:44 am
My recently bought Anthem which was in "excellent condition" needed the brakes bleeding and all the shock bolts doing up before I could ride it.
Posted : 02/09/2019 7:54 am
Cheers! I think I will go for decent allen keys & tools for some car park fettling. And the bread maker obviously 😀
Posted : 02/09/2019 8:30 am
Pedals.
Posted : 02/09/2019 8:31 am
Gear cable inner
Posted : 02/09/2019 11:05 am
Honestly, no way I would.
Even a brand new bike will get an hour on the stand making sure all is well. A second hand bike would likely get a full strip down before riding.
But they may be me being overly sensitive to set-up and overly worried about something breaking.
Posted : 02/09/2019 11:09 am
Shock bushes/sus bearings will be knackered.
Wheel bearings too.
Above seems about normal for "good nick".
Oh, if it has pedals, they will have knackered bearings/ bushes too.👍😁
EDIT: Forgot, lower headset bearings will be rusty.
Posted : 02/09/2019 11:14 am
We can go on about people being nice to each other on here all we want, but it is material like this that really makes this place.
Posted : 02/09/2019 11:17 am
I took a multitool and a tube. If it was to knackered to ride I wouldnt buy it!
Posted : 02/09/2019 11:20 am
Wheel bearings too.
Above seems about normal for “good nick”.
Oh, if it had petals, they will have knackered bearings/ bush too.👍😁
Probably not far off.
This was my reaction to start with. But then I thought why not? But ride accordingly - don't start leaping off stuff on your first 500m on the bike. A decent shake down ride might be much better at letting you know what's actually wrong with the bike the a workstand. You then know what to start with when it's on the stand 🙂 None of the stuff Poopscoop listed is really a reason to stop you riding it if it's already been ridden like that for a while anyway.
Posted : 02/09/2019 11:22 am
Maybe some chain connectors?? I never used to bother until the other day when I went one way and my chain the other
Posted : 02/09/2019 12:24 pm
I live in Warwickshire and went to collect a used fatbike from East Sussex.
I test rode it in the Surrey hills on the way home and it ended up in a tree.
[url= https://live.staticflickr.com/5078/30083676892_9d70e7fcb3_k.jp g" target="_blank">https://live.staticflickr.com/5078/30083676892_9d70e7fcb3_k.jp g"/> [/img][/url][url= https://flic.kr/p/MQoH3m ]Calibre dune. Surrey hills[/url] by [url= https://www.flickr.com/photos/79912681@N06/ ]blackteaonesugar[/url], on Flickr
Makes you think...
Posted : 02/09/2019 1:09 pm
there isn't much to go wrong with a rigid fatbike and that looks pretty new as well.
Posted : 02/09/2019 1:36 pm
So the correct answer was - bring your own bike or a working seatpost for the new one! And a decent spoke key.
The show stopper with the new one was a Reverb that woulnt stay up - or down. Apparently it had never happened before! It was a decent haggling point though. Bearing etc all good. Rear wheel was a bit of a pringle too.
Posted : 06/09/2019 10:55 pm
You happy though yeah?
Posted : 07/09/2019 7:11 am
I knew getting to ride it on the way back was a bit of a gamble. Apart from the above issues everything else seems in great condition = very happy! (hopefully tomorrow's post won't be about how to fix X,Y and Z ).
Posted : 07/09/2019 7:26 am
