Coils on Tracer...
[Closed] Coils on Tracer's.....
5 Users
Hi - just wondered if there are any Tracer VP owners that can comment; I've recently added a Pushed Van R to my Tracer an am experiencing (in this dry weather) near hardtail chatter/rattle/bumps over small gravel/stones/pebbles type single track.
The shock is great elsewhere giving me 90% travel through general singletrack indicating its setup correctly.
It could be the spring preload - or is this common with VPP / Coil combination?
Ta
Posted : 05/05/2011 9:44 am
Bump.
C'mon, I want to know how to make my initial Travel less harsh - would sticking the same shock in 6" mode help?
Posted : 05/05/2011 1:40 pm
This is purely a guess: adjust the pre-load perhaps? Coils generally have better small bump sensitivity.
If it is chattery on high speed hits, perhaps you need more rebound damping winding on.
You could also call Mojo - very helpful chaps there 🙂
Posted : 05/05/2011 1:58 pm
Swalsey - I'm assuming you mean "less" preload - issue with that is I'm only about .5 turn from contact with the spring.
Rebound is already quite slow giving a really comfortable, controlling feel on anything else (I'd probably have to bunny hop to get the wheel disconnect from the ground its that good).
Thats why I wondered whether its was a symptom of the VPP - but I dont remeber feeling is on my previous 5.5 with air.....
Posted : 05/05/2011 2:22 pm
Maybe try quickening the rebound? Could be that with the trails being so dry you're riding faster. Plus the ground is harder, making bumpy ground feel harsher.
Posted : 05/05/2011 2:31 pm
Lighter spring?
Posted : 05/05/2011 2:52 pm
I'm 12st and the spring is 450 - bang on according to TfT's and Fox's calculators....
As mentioned I get 90% travel on singletrack so a lighter spring wont do me any favours.
Again - is really a question of is this Tracer/vpp -esque
Posted : 05/05/2011 3:14 pm
 Dino
Too much crompression tune??
Try it in 6 inch mode as the rear wheel will have a bit more leverage over the shock ( worth a shot as it's quick and free) also the tracer has a higher leverage ratio than the blur lt if memory serves me correctly with a slight rise at the beginning of travel and falls away through the travel,
if ure only running 1/2 turn pre load it's un likely to be spring more likely compression on the shock
Posted : 05/05/2011 3:38 pm
Dino - I think you're on to something. I've remembered now that whilst discussing the Push with TfT I did ask for "Trail firm". with the limited adjustment on the Van R I'm guessing they would have upped the compression tune as you say, which is why on bigger bumps/roots it opens up nicely.
Could be good news for racing though, if only it was several lbs lighter..... 🙂
Will give 6" a go as you say, Cheers.
Posted : 05/05/2011 3:51 pm
Dino - to explain the "leverage ratio / slight rise" in laymens terms - you mean its harder to get through the intial part of the stroke, then opens up more right?
Posted : 05/05/2011 3:53 pm
 Dino
Yep spot 😛
plenty of stuff on Intese forum of MTBR
Posted : 05/05/2011 5:25 pm
