Coil U-Turn Lyriks ...
[Closed] Coil U-Turn Lyriks question...
4 Users
 scud
Afternoon all,
I have Coil U-turn Lyriks currently fitted with X-firm spring due to my ample fighting weight (105kg). Even with the firmest spring, I still find that the forks can dive too much, what is the best way to tune the fork with regards to the low/ high speed compression on the Motion Control damper to counter act this?
Do I need to have the low speed compression dialled right up?
Posted : 21/03/2012 3:54 pm
Low to slow brake dive, but you could also up the weight of the damping oil which will slow it all down (including rebound).
Posted : 21/03/2012 3:56 pm
what he says, plus this
is useful
Posted : 21/03/2012 3:58 pm
 scud
Cheers guys, very helpful.
Posted : 21/03/2012 4:00 pm
up the floodgate?
Posted : 21/03/2012 4:01 pm
If you dont use the floodgate you can remove it completely-
[url= http://www.pinkbike.com/news/technical-tuesday-lyric-mod-2010.html ]http://www.pinkbike.com/news/technical-tuesday-lyric-mod-2010.html[/url]
Posted : 21/03/2012 4:03 pm
