Coil Conversion for...
[Closed] Coil Conversion for the Pike
64 Users
Just finished fitting mine in the Pikes today.
Decided to have a bit of a maintenance day, cold, wet and windy outside.
Have only managed to have a quick ride on the road to bounce up and down on the forks.
Will have to get out later in the week to test properly.
Took my time, sometimes I scratched my head, but I'm sure I have fitted it correctly.
Mine came with a white plastic spacer, I have put this on top of the coil. My forks are set at 140mm , the installation images on the net don't show this though.
Posted : 06/02/2017 4:04 pm
An extra spacer as well as the one that sits in the air cap? Interesting, might just be a preload spacer for you?
Posted : 06/02/2017 4:11 pm
After a day of uplift I am very happy with my coil, thanks Tom_W1987 for kicking this whole thing off 🙂
Posted : 10/02/2017 9:02 am
Glad it worked out well for you RB!
In the spring I'll be ordering an Ohlins coil and I'd like to look at getting a company to knock me up a dual rate spring (main spring, plus secondary spring for either bottom out or ride height - plus a cross over ring to control the point at which the secondary spring kicks in)... for my next round of stupidty....need to do a bit more research though.
Posted : 10/02/2017 8:00 pm
Any thoughts on the conversion RB?
I'm keen to ascertain whether I'm as nuts/deluded as a hi-fi enthusiast etc
Posted : 10/02/2017 8:28 pm
2nd ride on mine today. Still a big thumbs up. Interestingly I'm actually getting more travel out of them than when I was running air, but they still feel far better supporting/less wallowy.
Still making a slight noise, but as I haven't bothered doing anything about it then that's not a surprise
Posted : 10/02/2017 9:57 pm
Yeah, thats me experience. I was expecting to use a bit more travel and I mentioned it in the review, the more progressive you run your fork the more you have to drop the psi to achieve the same sag which seems to worsen midstroke support.
More blow off in rock gardens has meant a smoother ride - yet the fork is still more supportive in berms and steep tech. The FAST dampers high speed adjuster is really effective as well....so im able to dial out the odd bottom out harshness.
Posted : 10/02/2017 10:24 pm
I hesitate to give my opinion due to my general ignorance but..
I used to like my Pikes. They came on my first long travel bike with a Rock Shox shock at the back. It all worked well together at the modest speeds I travel and all the magazine reviews were full of praise so why would I want anything else, everything was great.
Then I bought a new frame. Longer, lower, slacker you get the picture 🙂 It came with a CCDB inline (I know, but I've had no trouble yet and it feels great). I swapped all the parts from my old bike including the Pike. Only now the Pike didn't seem so good. The action in the first half of the travel felt too restricted, not free moving enough is how I would describe it. If I reduced the air pressure or low speed compression it was a little better but I had too much dive so had to go back. I don't know if it was that the new bikes rear set up was better so the Pike suffered by comparison or the super slack angles were increasing friction in the fork but it was nagging at me that something needed changing. But I didn't know what.
Then I saw this thread and got interested. A coil spring sounded good, a linear rate suits me (so long as it doesn't bottom too much too hard) and doing away with those air seals has got to reduce friction right? So here I am with the coil conversion. It feels far better in the first half of the forks travel, the suspension moves so freely without diving or resorting to more compression damping than I'd like. I have no idea about the action in the second half of the travel since my brain at these times is too busy with other things. I haven't bottomed the fork in my one damp day of riding so will see how that goes as summer dries the trails.
I am really happy with this conversion. I still have the standard charger damper so maybe there are further improvements to be had but.... for a rider of my limited talent... I think the coil alone has given me what I wanted.
Posted : 11/02/2017 9:37 am
^ that was a bit more of a ramble than I intended 😯
TLDR? The short version is 😀 😀 😀
Posted : 11/02/2017 9:41 am
Have you thought about a custom wound spring with progression built in?
Posted : 11/02/2017 10:13 am
Do those actually work though, for example dual rate springs don't actually work unless the softer spring is so soft it totally binds before the harder spring can be compressed. To get a true dual rate setup you need a cross over nut to stop the two rates combining as one rate.
http://shocktherapyst.com/the-truth-about-dual-rate-springs/
I haven't done enough research yet and perhaps I'm being thick, but I don't see why progressive springs would be any different?
Posted : 11/02/2017 2:11 pm
Well they do work in so far as they give a rising rate as the closer coils bind. But having scanned through your link maybe they don't do what you want which appears to be two spring rates?
Posted : 11/02/2017 3:42 pm
I've been following this thread with interest for a while, certainly as an upgrade to my 2017 Lyrik RC DPA.
I can set it up with 3 tokens to get a nice initial stroke, but it doesn't feel as supportive as I'd like, or I can remove a token, run higher pressures to get what feels like more mid support, yet it becomes harsh and a bit reluctant to move through the travel on choppy washboard type stuff. Instead of the wheel tracking the ground it feels as if it is skipping.
What I don't know is if I am confusing what I think is mid stroke support with actually a too high spring rate (which a coil wouldn't fix as I understand it's inherently higher after the sag point compared to air), or if it's an issue with the RC charger damper and it's poor HSC tune (relative to an RCT3), or a friction issue because of the many seals in the dual position air spring assembly (which a coil would fix)
~72 kg, 105 PSI 20% sag (2 tokens) or 90 PSI 20% sag (3 tokens)
Any tips welcomed
Posted : 13/02/2017 9:32 am
Just been out today for the first ride on the bike with the coil fitted.
Sag measurement is about 25% which is just about where I would set up the air spring.
Small bump performance is noticeable better, didn't feel that great today though, so I'll have to reserve my final judgement for the future. Almost certain that it will be favourable, the support in the mid stroke, as others have mentioned, is much firmer and doesn't blow through the travel as easily.
Posted : 13/02/2017 4:47 pm
I'd say the buggest issue is that youre running even more seals with the DPA fork, Icantride.
I think a coil would fix the issues you describe, when you go to a more linear setup - how much sag do you run?
Anyway im 12 stone 5lb and I moved from 21 percent sag on air and two tokens (1 token when I moved to a FAST cartridge) to 21 percent sag on a coil and havent noticed increased harshness on braking bumps etc, so the increased midstroke support hasnt harshened the fork further.
If anything because the fork is livlier in the upper part of the travel, its rebounding bsck and staying in a softer parts of its travel better on the braking bumps. You can feel the somewhat increased playfulness everywhere as well...
If you want the same bottom out resistance with the coil ho with a lottle less sag than you tun with air....if you want to use a little more....like I did...run the same. Either way you'll get better small bump tracking I reckon.
Posted : 13/02/2017 7:54 pm
Tom where are you based? I also have the FAST damper upgrade and after yesterday's arm pump fiasco at BPW I'm keen to get a coil spring in mine, the small bump sensitivity of the air springs is dreadful!
Posted : 13/02/2017 8:35 pm
I definitely think the extra seals are playing a big part in it. It's a new bike (Slash 29), only 5 rides old so I'm yet to go token-less and try out that extreme. I'm working on sorting the rear too.
What I want is something that is supportive yet active/supple, if that's not an oxymoron/impossibility in the world of suspension. To my mind the support comes from the spring rate, the suppleness comes from the damper and friction from seals (or lack of)
Posted : 13/02/2017 9:36 pm
How much did you play with the balance of the LSC/HSS at BPW chilled? I found that getting the balance right in terms of support vs comfort for all day lift assisted riding was pretty critical with the FAST damper - but it's also the highlight of the fork - being able to find your happy medium, on shorter days I run it a lot stiffer (and it's more of a race tune in the first place) than longer days.
At Antur I dropped to 4 clicks of HSC from 7 from fully open, and upped the LSC from 10 to 12 clicks from fully open. I found that LSC barely affected feedback and that actually increasing it seemed to cause the high speed circuits to blow off more easily - as I assume the fork was forcing more oil through the high speed circuits. That could easily be in my head though.
That's the nice thing about the FAST cartidge, anywhere between 4 and 11 clicks of HSC works for me - but for different types of riding. Chicksands feels nice running 10 and seems to make jumping a bit more fun/less hairy.
I ride around Sheffield now but based in London, will be up there in a couple of weeks if you are near by and want to meet up. My ankle is still pretty shagged though, so I probably won't be keeping up with anyone.
In reality support comes from both, in WRC I've read that suspension setup has moved on from the time when the spring supported suspension through it's stroke to the point that it simply holds the car at sag point and the damping does most of the work. I'm not sure that's the case with the MTB world, or whether I was reading bullshit - I'm not sure MTB suspension could package that level of engineering into such small volumes either. But my feeling is that going to a coil effects midstroke support and suppleness more, my FAST damper improved the performance on and reactivity to deeper repetitive hits more. My setup currently feels like it's a little way to what is described by some WRC tech heads - the coil and damping are holding the fork up in the midstroke, yet the damping blows off pretty nicealy at high speed and the linear coil accentuates this and I can alter how much travel the fork uses a bit, by simply tweaking the HSC setting.
However all suspension is a compromise, for now anyway....maybe in 20 years they won't be. It's about finding the trade off that suits you as an individual, instead of taking what mags say on face value.
Posted : 13/02/2017 10:06 pm
I'd like to add something to my final point as well, magazines and the bike industry have been encouraging people to move to more basic adjustments (eg three position compression) etc - when clearly there are a lot of people who aren't quite happy with their setups and are resorting to fairly pricey aftermarket upgrades. This was done in the name of simplicity, I've even seen forks being marked down for having too many adjustments (looking at you NSMB).
When what the industry should have been doing is keeping the adjustments, letting people have the choice - and get this....properly educating them on how to set up suspension - the amount of people that just twiddle with suspension boggles my mind. You have to go out, for at LEAST one full day, with the sole intention of setting up your suspension by repeating a piece of varied track over and over again. Even if the idea bores you to death, you need to take a notepad with you, note your base settings and then use the bracketing method to home in on your standard setup.
This is great even if you aren't a particularly experienced rider, why? Because it gets you in tune with your bike, you learn about how you ride and how your bike handles by making noticable changes to it and having to ride around the perhaps odd way that your new setting rides. It makes you think about what you are doing with your bike and your body more.
I improve my riding the most when I'm sodding about with the suspension fairly seriously, not because the bike is suddenly making me ride faster - but the whole process makes me think about how I'm riding the bike! Go to extremes with your bike, try full fast and full slow on the rebound...for the lolz...see how it feels....then bracket inwards.
Posted : 13/02/2017 10:27 pm
Hi Tom, yeh I was fiddling with the compression but ended up winding it pretty much off in an effort to get the fork more supple.
I've come home now and realised I probably need to run a lot less pressure in the air spring and have had a play with lower pressures... doh!
All good fun though. I really want more small bump sensitivity and that's something I don't think an air spring can give me without enough mid stroke support.
I've emailed Richard at CRCONCEPTION and he emailed back saying use the online order form... but it's all in French and I can't make head nor tail of it lol.
I'll have to sit with Google translate and have a look a it.
Posted : 14/02/2017 8:19 am
Just email him in English your riding weight, your fork model eg wheel size and length and your rough desired sag - thats what the rest of us did i think and then he sent us a paypal link.
Posted : 14/02/2017 8:38 am
Think both myself and R_B used the order form as requested. You can work out what most of it is, lots of the boxes have English comments attached if you hover over them. Failing that, Google will sort you out
Posted : 14/02/2017 8:42 am
Think he's getting fed up with emails hence sending me the order form
Posted : 14/02/2017 10:12 am
I used the spreadsheet, as legend says there are comments in English (and other languages) if you hover. Some of the entries were maybe a little unclear in translation but mostly I thought fairly easy to work out what was required. I included a few comments in my covering email just to make sure I hadn't misunderstood.
Posted : 14/02/2017 10:24 am
After yesterday's ride I perhaps began over thinking this, but here goes.
The small bump sensitivity is much better, no question, the static sag is spot on.
Next ride out, thinking about slowing the rebound down a tad. This is mainly due to how the coil seems to be much more controlled and I'm not getting that close to the full travel.
Any thoughts?
Posted : 14/02/2017 11:12 am
Someone with more idea will hopefully answer but
[s]No harm in that, turn it down until you go too far then come back to where it feels right[/s] Hang on, I misread that. Why slow the rebound unless you have a symptom of too fast rebound?
Have you been riding terrain/in a manner where you would expect to be approaching full travel? If so, do you have too much compression damping? Currently I have reduced low speed compression from what I was using with the air spring (caveat: I'm far from expert and I've had only one wet day out on it so far) I have about 22mm of sag and only used approx 135mm of travel so about 25mm unused but I expect that margin to diminish in drier conditions when I'm not feeling so chicken 🙂
Posted : 14/02/2017 11:42 am
Thanks rubber buccaneer.
Food for thought there.
Will experiment next time out.
Posted : 14/02/2017 11:46 am
Some say you should be getting full travel every ride but I don't agree with that, especially when you have 160mm of travel. I'd have to turn my forks into a right wallowy mess for some of my 'Extreme Canal Tow Path' riding 🙂
Posted : 14/02/2017 11:51 am
apologies, I said I had 22mm of sag but I meant 35mm (22%)
Posted : 14/02/2017 12:02 pm
I have a set of Lyriks which I converted to coils using a crconception kit, I've actually decided to go back to air, a lot has to do with the fact my lyriks are a bit creaky in the uppers and will probably get warrantied at some point (be a bit tricky with a coil in there) and also I'm actually quite happy with the air shock on the Lyrik.
Anyhow, the upshot of this is that I now have a coil kit to get rid of so if anyone is interested in getting a kit cheap let me know, the kit is for a 160mm lyrik I'm sure it will be fine in the pike, the only thing I can see different to Richards instructional pics is that it has a white spacer under the air cap rather than an insert.
My weight is around 12.3 stone, which with the kit gave me approx 23-25% sag.
The only thing you may need is a fresh sheet of acetate to go inside the stantion although the existing one could most likely be used again.
Posted : 14/02/2017 12:09 pm
Any of the upgrade options out there that work with the Dual Position Pike?
Posted : 14/02/2017 12:42 pm
Do you mean you want to keep the ability to lower the travel? If so, no there's not a coil kit that will currently do that
Posted : 14/02/2017 12:47 pm
You could try to mod a Lyrik Coil U-turn spring. I converted a set of U-turn Dual Air Revs to U-turn coil using U-turn coil bits from an old set of Psylo SL's.
Only did it after I accidentally put a tiny scratch in the air tube.
Posted : 14/02/2017 12:52 pm
As others have pointed out, try torquing the top caps up more to get tid of creaks in Pikes and Lyriks.
You dont want to needlessly slow the rebound down, you want it to stay higher in its travel and not pack down into its deep stroke brcause this means the fork is staying in the softer parts of its travel. Only slow it down to the point where the front isnt fighting you in rock gardens, pushing you out wide in berms or giving you a bucking sensation.
I use a bit more travel on single hard impacts, not much over a two spacer air setup. But in tock gardens I actually use less - despite the fork feeling more compliant - I can only assume the fork is reacting quicker and riding higher due to less seals and more midstroke support.
Be methodical with setup as well, try full slow and full fast rebound and move inwards, trying a click or two in from open and closed in an alternating fashion. Do this on a single track/section and note down what you notice about each setting.
Posted : 14/02/2017 1:02 pm
Ta
Posted : 14/02/2017 1:29 pm
Travo if you're sure it will fit I'm keen. Will pm you
Posted : 14/02/2017 3:38 pm
I assume, given the free length of the spring, that it doesn't get close to coil bound. So, in theory, could I order a 140mm kit for ,160mm pike and put a 20mm spacer on top of the spring? Then, if I want to shorten the travel, move the spacer to the spring rod? Pretty much like the original Fox vanilla forks?
Posted : 16/02/2017 9:09 am
The theory there is probably sound, just so happen to have been reminding myself of how to lower an old set of Fox 125s the other day. No idea about the spring length part of the assumption though.
I do think you'd struggle to use the same spacer when you switch the travel though, as there's not much room to make sure you hit the negative spring
Posted : 16/02/2017 9:56 am
This is all purely speculative as I'm in the process of selecting a new frame, but an Airdrop Edit with cc coil IL is in the lead right now. Feels better with a 150 fork though.
Posted : 16/02/2017 11:26 am
I've been keeping an eye on the Super Alloy Racing 'PSP' coil conversion, apparently a press release will be out tomorrow, but release date likely not until spring, not sure I'll wait that long, I have a few more token variations to try and see if I can find what I'm after before I bite the coil bullet.
The hydraulic bottom out does sound interesting, but is likely to add more cost over a CRC conversion. Does the CRC kit have anything in the way of bottom out protection?
Posted : 16/02/2017 10:16 pm
It alludes to it in the pictures - but I'm not so sure - it has something to do with that ring at the bottom of the lowers that is left in the Pike - it's the standard bottom out bumper I think. Maybe someone should ask Richard.
Although it wouldn't be hard to put an elastomer in there, like coil shocks have.
Posted : 16/02/2017 10:26 pm
I'm looking forward to seeing this one, which I recon is the one TF are talking about:
[URL= http://img.photobucket.com/albums/v444/RickDraper/18C59662-134A-4C87-A620-9A9666CD1423.jpe g" target="_blank">http://img.photobucket.com/albums/v444/RickDraper/18C59662-134A-4C87-A620-9A9666CD1423.jpe g"/> [/IMG][/URL]
Posted : 17/02/2017 4:21 am
Has anyone on here got a crconception kit to hand? I'd like to get the pike kit measurements, (spring length and also the lower leg rod length too) if it's not too much trouble.
Just want to compare with my lyrik kit.
Posted : 17/02/2017 9:51 am
are those ear plugs?
Posted : 17/02/2017 10:36 am
 Neb
I put on a bit of weight last year, didn't bike much for various reasons, so I'm a fair bit heavier than I have been when I'm fit. I also often ride my bike with no rucksack and sometimes with a heavy rucksack for a big day out. So there's quite a variation in my riding possible weight...
I reckon that the lightest I'd be ready to ride is 80kg and the heaviest is 94kg.
Am i right in saying a 17.5% increase in riding weight = a 17.5% increase in sag (in mm)? So 20% (32mm) sag at 80kg = 23.5% (37.6mm) at 94kg??
Posted : 17/02/2017 3:56 pm
Not unless you ride a unicycle 🙂
Though I suppose it will still be proportional so you could be about right
Posted : 17/02/2017 3:58 pm
I'm tempted to try a DIY coil conversion using coil Lyrik parts. Have read on mtbr that it works, only sticking point would be getting the right length and rate of spring.
In my head I need a Lyrik 160mm spring shaft (cut down and threaded to give the right travel) 11.4015.421.020 (or a 170 cut down more), a Lyrik top out spring 11.4015.458.010, Lyrik spring sleeve to protect the inner stanchion 11.4015.205.000 and finally the difficult bit, an appropriate length, diameter and rate spring. I guess I'd have to fit the other bits then measure the spring length required? All the above parts excluding spring would be ~£60 then i'd hope I can get away with a cheap off the shelf spring
Posted : 17/02/2017 5:06 pm
I would say that going from 20 to 23 percent sag is pretty unnoticable. 20 is still going to feel more sensitive than 23 with air and I reckon 23 with coil will still feel more supportive than 20 percent sag with air. I dont think that is enough of a margin of variation to outweigh the performance differences of coil vs air.
Posted : 17/02/2017 6:48 pm
 Neb
That's kind of the conclusion I've come to. I wouldn't want less than 20% sag or more than 25%. So the coil looks a goer now rather than in 6 months after I've lost a bit of weight.
Posted : 17/02/2017 6:55 pm
No need to rush - lose some weight if you want and have the coil as a prize for doing so. Or if you do lose it and you find yourself wanting a new spring, I would say it would be quite useful to have two spring rates. One for racing or jumping and one for all day riding, seeing as the springs are so easy to drop in once the lower assembly is installed.
Posted : 17/02/2017 7:12 pm
That's going to end up close to 100 quid isn't it. For not much more, you can choose out of 10 spring rates instead of 5.
Posted : 17/02/2017 7:14 pm
I could probably save £20 and skip the lyrik top out spring and use the rubber one out of the Pike? Or, go full DIY and turn down the pike air spring piston diameter .5mm or so, bolt something through the top of the piston to make it a top hat shape to retain a spring and just find a spring and some acetate?
Posted : 18/02/2017 2:19 pm
Joined the coil revolution today when I picked up a mint X-Fusion Vengeance....at 170mm travel I can't decide whether to run it on my HT to make a brute of a thing or stick it on the front of my Trance giving me an Enduro-tastic 170mm front and 156mm rear.....decisions decisions.
Also arrived today was a saddle weighing less than 100gms....gonna weigh the Trance later with its air suspension and see what I get, I'll be disappointed if it's over 30lbs.
Posted : 18/02/2017 2:26 pm
Just by way of some proper feedback on the coil conversion.
Installation is fairly straightforward, so I won't dwell on that, relatively easy to do, just take your time and make sure everything is very clean etc.
Today was my first real ride in anger.
Rebound was a tad slower than I have had in the past, just felt a little better like that for me.
Sag is at about 25%, my Pikes have been altered to 140mm.
Played around with the low speed compression damping , couple of clicks out, about 5 from fully closed.
Impressed, much firmer feel without being harsh, doesn't go through the travel as easy, although I almost achieved full travel at 135mm.
The biggest thing for me is how much more in control and firmer the fork now feels.
Anyone sitting on the fence should really consider this mod.
I have another bike with a dual travel Pike on it. Will be doing this mod for the Pike, don't use the travel reduction thing anyway.
Posted : 18/02/2017 2:33 pm
Any tips or feedback on the ordering process? The website looks a little light on info irrespective of the language barrier.
Posted : 18/02/2017 8:08 pm
I emailed Richard directly, he was very helpful in pointing me in the right direction.
Just include the details of what you want in the email.
Posted : 18/02/2017 8:19 pm
Cheers.
Posted : 18/02/2017 8:38 pm
Ask for whatever info you'd like and I'd expect someone can help, there are a few of us have the kits now.
Edit: have you got the order spreadsheet? It covers all the detail about weight etc
Posted : 18/02/2017 9:37 pm
So I went on another ride, this time with 0 tokens and 120PSI, it gave about 11% sag. Mid stroke was improved on anything I had when running tokens, and small bump wasn't [i]as[/i] bad as I was expecting. I certainly could live with what I've got, and my Lyrik is better than a friend's Pike, but I still think I'm on a compromise, and since there's a mod out there that will give me even more sensitivity with the support I'm after, and it's not super expensive, I think it's a no-brainer, so I'll be sending off an order form sometime this afternoon
Posted : 19/02/2017 1:45 pm
Also when the install instructions say add 10 ml of oil, does it matter what weight oil is used? I have a bottle of Fox 10W Green and Fox Float Fluid hanging around in the garage
Posted : 19/02/2017 1:57 pm
I'd use standard weight rock shox oil....
Posted : 19/02/2017 2:19 pm
I stuck with the same rock shox oil I'd always use for a lower leg service
Posted : 19/02/2017 3:14 pm
Given that the spring leg becomes one large volume, I guess the 10ml isn't that critical. I might be tempted to add a little more.
Posted : 19/02/2017 4:08 pm
ordered the spring kit for my pikes today - hope its as good as you lot say - I may be back for advice when it arrives and I need to install it
Posted : 20/02/2017 2:09 pm
This took off more than I thought it would!
Posted : 20/02/2017 4:05 pm
I too sent off an email this afternoon, waiting on a reply though
Posted : 20/02/2017 4:59 pm
Tom_W1987 - Member
Nine pages and it's a thread about bikes, something of a rarity around here 🙂 I haven't counted up how many orders you've generated
Posted : 20/02/2017 5:43 pm
Ok late to this but, I've got a pair of 27.5/160mm pikes with a few scratches on the stantions and the damper has a bulge near the bottom of the rubber bellows bit.
Could these be used for a coil conversion or not???
Was planning to e bay as Spaire or repair but fancy try as coil if this is a possibility.
Posted : 20/02/2017 7:41 pm
Don't see why not. The rubber bladder part of the Charger damper is available as a service item AFAIK.
Posted : 20/02/2017 7:45 pm
I hope all the coil upgrades worked out well for you lot this weekend.
Hows the rattle issue legend?
I've just been comparing two FAST equipped forks, my coil equipped Pike and an MRP Ramp Control equipped air 170mm Lyrik. The difference in grip and feel is a little bit nuts actually - it's more noticeable when you go back to air. The longer legged Lyrik, has only what I can describe as a more rounded feel to the information that is coming through the bars - yet it doesn't grip as well on the wet hardpack on the steel city DH at Greno. The coil gives a bit more feedback (but not the kind of harsh feedback that causes hand fatigue) - and more grip, it's hard to say how much - but it is there and pretty obvious to boot. The coil seems to be better at keeping the front wheel tracking the terrain, whilst the air can feel a little softer until you ride through repeated hits where the fork doesn't react to the terrain as well.
The more I'm riding it, the happier I am.
Posted : 26/02/2017 2:52 pm
I'm hamstrung by the lack of top cap at the moment, Richard can't source one, but ended an email with "stay tuned" whether that means he's got a plan to make custom machined top caps himself I don't know. I'm seeing if my LBS can get their hands on one.
Unfortunately I think it means I'll be riding BPW next weekend with air.
After running 0 tokens and 120 PSI to get mid stroke support this weekend, my hands were blown up and I was feeling the front wheel skipping instead of tracking. Might have to revert back to wallow-y tokens just for a bit of traction next weekend.
Coil can't come soon enough
Posted : 28/02/2017 3:56 pm
Tom_W1987 - Member
No rattle, just a gentle occasional squeak. Have had the spring out, extra grease, flipped upside down, re-seated, etc, etc and it's still there. It's a non-issue tbh, think I only ever actually hear it on climbs. Also cant make it do it with the spring out, so 99% it's just flexing off the inner wall of the stanchion.
Posted : 28/02/2017 4:01 pm
Errr....Icantride....literally my first google hit.
https://www.bike-components.de/en/RockShox/Air-Top-Cap-Solo-Air-fuer-Pike-Modell-2014-2016-p37285/
Let me know if Richard decides to make his own topcap though, I wouldn't mind one anodized purple to match my FAST damper...because...I'm a tart.
Posted : 28/02/2017 8:43 pm
Tom, the lyrik uses a different thread pitch to a 2014-16 Pike.
Posted : 28/02/2017 8:53 pm
Ahhh, forgot he had a Lyrik.
In that case
https://www.bike-components.de/en/RockShox/Air-Top-Cap-Solo-Air-fuer-Lyrik-Modell-2010-2016-p50986/
Not sure that's the right one though, googling the part number brings up images of a much older design.
Posted : 28/02/2017 9:07 pm
http://www.artscyclery.com/Rock_Shox_Solo_Air_Top_Cap_Pike_Lyrik_Yari_Boost_Forks/descpage-RSPTBFB.html
Googling "Yari Top Cap" brings up a few results. Again, I'm not sure that's right as it says it's compatible with non boost Pike forks as well. 🙁
Posted : 28/02/2017 9:12 pm
Based on this http://www.mountainbikes.net/mtbikes/ersatzteile.cfm?gnr=228
my last link looks like to be the right part number?
Posted : 28/02/2017 9:18 pm
LBS say that the UK distributor for Rockshox don't have the part. A lot of the links posted are also out of stock or the wrong cap. By the looks of it ordering off ebay from america seems to be the only place to source them
Posted : 01/03/2017 2:02 pm
Has anyone else experienced a loss in available travel upon installing their coil kit?
Got mine today, the kit comprising a spring, shaft with top hat, white spacer, sheet of acetate and spring clip. Installed with the white spacer at the base of the shaft at the base of the leg. When it was all bolted together again I seem to be sitting at the 10% sag marker on my 160mm pikes giving less than 150mm travel with no weight (not even the bike) on the forks. I can pull the fork out to show the full 160mm but they suck back.
Has everyone else got the amount of travel expected from their fork?
Posted : 13/03/2017 10:04 pm
the white spacer is actually the pre-load "spacer" and it goes on top of the spring not at the bottom.
Posted : 13/03/2017 10:11 pm
Page 4 / 6
