The Ride 50 in my gravel bike makes an annoying clicking sound when pedaling. It doesn't seem to affect the performance but is loud and irritating. It's only done a thousand miles or so but I have checked most obvious things . Motor bolts torqued correctly, crank arms tight, pedals brand new and tight on cranks, any other ideas for the cause?
Chain ring on tight?
Tooth bent or missing on chain ring?
Pedal bearing worn out?
Can't help with the cause. I had exactly the same and LBS (also Fazua service centre) fixed it for me and its been fine since. I realise this is unhelpful if you want to solve it yourself. Hope you get it fixed.
