I've acquired a pair of these from a chap at work. I'm something of a tubeless naive - I've fitted some X'PLOR MSH folders tubeless sucessfully once, that's it - wonder if the USH will go up ? IS wire bead a no-no ?
Thanks
I've got a pair running on some Stan's Grail rims with Stan's rim tape and sealant.
They seem to be OK running up to about 60psi. I've had them higher (purely in the interests of science...) but managed to blow one off the rim whilst inflating at 70psi. I've had them running higher than that as well.
Seating them was a bit of a faff. Normally takes a couple of attempts with a small compressor. I haven't tried with any of the pressurised reservoir solutions to know if this makes it any easier.
