Cleat wear: signs a...
[Closed] Cleat wear: signs and symptoms?
5 Users
Hello All,
How do I tell if my cleats are worn and need replacing? They look okay but they seem to be moving about a bit and making an annoying clicking noise.
Dogsby
Posted : 09/07/2015 9:58 pm
Generally if they move about and make a clicking noise they need replaced.
Is it more difficult to unclip now? Is there a lot of float where there was none? Are there shiny bits of metal where the pedal has worn away the cleat? If so, replace.
Posted : 09/07/2015 11:12 pm
For Shimano: Harder to unclip when you want to. More float than you want and more inadvertent unclipping. Clicking etc just sounds like you need a bit of grease somewhere.
I don't know about other brands.
Posted : 09/07/2015 11:21 pm
If they unclip inadvertently, try tightening up the pedals - if that doesn't do the trick then the cleats probably need replacing.
Posted : 10/07/2015 12:40 am
Cheers All,
I will try tightening the pedal and see if it makes a difference.
Dogsby
Posted : 10/07/2015 8:42 am
Have shimano changed their cleat material? I seem to have worn out my last couple of sets really quickly.
Posted : 10/07/2015 9:01 am
