Cleat stuck in peda...
[Closed] Cleat stuck in pedal HELP
8 Users
Afternoon all, been out riding and had a comedy off, tried to unclip foot but it twisted all the way.
I changed the position last night so probably my own making however how do I get it out? Shimano cleats on xt trail pedals.
Any suggestions
Ash
Posted : 31/10/2012 2:26 pm
Not sure I understand!
Did the cleat come off the shoe and is stuck in the pedal?
Posted : 31/10/2012 2:37 pm
In which case you need a screwdriver and an allen key, so you can tighten your cleats properly next time.
Posted : 31/10/2012 2:39 pm
Are you still attached to the bike? Probably best to take your shoe off first... 😉
Posted : 31/10/2012 2:41 pm
Back the spring tension off all they way and lever the sprung rear binding open with a screwdriver, this should release the cleat.
Posted : 31/10/2012 2:54 pm
No not currently attached to the bike, but the shoe is. It looks and feels like a bolt has either sheared or come out entirely meaning the shoe can turn 360 in the pedal itself.
Njee- screwdriver? And thanks for the advice about Allen keys.
I have removed the pedal as its raining. But cannot for the life of me work out how to get it out. If I wind the tension screw right off will it pop out?
Put the pedal back on the bike, stick a screwdriver into the sprung bit, lever it backwards and shoe will fall out. You've not tightened the cleat up enough and have maybe lost a screw as well.
Posted : 31/10/2012 2:55 pm
Can you get to the big phillips screws that hold the spring loaded plates on?
Posted : 31/10/2012 2:58 pm
It probably won't fall out but you should be able to lever it out easily enough with the tension wound down. (This is how I get the plastic reflectors out that come with new bikes!)
Posted : 31/10/2012 3:03 pm
Managed to get it out. Wound the tension off then managed to prise it off the cleat.
Lost a cleat bolt but hey I'm sure I can replace that!
Thanks for the advice everybody.
Ash
Posted : 31/10/2012 3:10 pm
bigyinn - Member
No need to thank me, all part of the service! 😉
Posted : 31/10/2012 3:53 pm
