Cleaning/polishing ...
[Closed] Cleaning/polishing anodised frames
6 Users
Morning All
I have an On One SCANDal frame that needs a good clean & polish prior to being built up tomorrow. Having never had an anodised frame before is there anything I should avoid using on it like the plague or is it just a case of crack on with the Fenwicks/Muc Off/Car Wash as before?
Will degreaser damage the finish?
Will beavers attack if I use the wrong unguant 😆
Sorry if this seems obvious but it never hurts to check 😉
Posted : 04/04/2010 1:50 pm
Wash it normally, if you want it shiny rub down with a rag and gt85.
Posted : 04/04/2010 1:54 pm
GT85 does make the shiny, but Juice Lubes Fork Juice makes them uber shiny. It's a dream for the polishers out there, and it stops as much mud sticking to your bike.
I've been using Fenwick's FS1 (1:10 diluted) to clean my ano bikes for ages and they come up like new.
Posted : 04/04/2010 2:56 pm
excellent stuff will get busy cleaning. Am planning to copter tape the frame, if I polish it first will the copter tape still stick?
Not heard of Juice Lubes Fork Juice but will investigate 😉
Posted : 04/04/2010 4:04 pm
No, you should thoroughly degrease anywhere you plan on sticking heli tape using brake cleaner/methylated spirits/isopropryl alcohol or similar.
Let the heli tape stick properly before spraying it down with GT85 and a rag. Does work well though.
Posted : 04/04/2010 5:09 pm
non of my mtbs look like new because I fall off and they get scratched out on the trails.How does anyone keep an mtb looking like new unless they don't use it?
Posted : 04/04/2010 5:59 pm
With the frame being anodised can I still put copter tape on it or would that stop it sticking?
Posted : 05/04/2010 10:06 am
 Del
depends how 'lumpy' the finish is, and how hard it is, as to whether it's actually required. the anodising on our machines at work is very hard - i can apply a razor with some weight without marking it for instance. follow above advice wrt degreasing, and if it don't stick, it won't do any harm, will it?
Posted : 05/04/2010 4:11 pm
