Cleaning out tubele...
[Closed] Cleaning out tubeless tyres
9 Users
Just got some second hand UST tyres that have been pre-gunked (possibly with latex glue) which has left a lovely dry mess inside.
Anyone got any suggestions on the best way to clean them out?
Cheers!
Posted : 21/02/2011 10:43 pm
Lots of soapy water and a pan cleaner
As long as the beads are clear and there are no big lumps they'll be fine
Posted : 21/02/2011 10:45 pm
very good question i tend to just leave them and add further gunk over the top.
the biggest problem is the gunk around the tyre bead which stops it from sealing properly.
Posted : 21/02/2011 10:50 pm
Pan cleaner? Seriously? Doesn't that tear up the threads on the inside of the tyre?
Posted : 22/02/2011 3:00 pm
I just rub it off by hand, it's slow but it works. Pan scourer does work but not as well in my experience.
Posted : 22/02/2011 3:04 pm
Sit for an hour picking it off by hand, get fed up and bin it.
Posted : 22/02/2011 3:10 pm
I peel most off then just scrub it with a brush, it is fairly tedious though
Posted : 22/02/2011 3:17 pm
Looks like it's a night of soapy water and rubber for me then.
Posted : 22/02/2011 3:18 pm
Kinky
Posted : 22/02/2011 3:25 pm
I use a wire pan scrubby thingy on Evo Schwalbe tyres, works fairly well. Works better on the bead, and do it with washing up liquid, you can usually pick it off the carcass if you're fairly careful, IME it's the easiest way.
I have the same problem. I ignore it and put them back on the bike. out of site etc
Posted : 22/02/2011 4:39 pm
