Any advice on washing? Previously washed Event and gore Tex active shell with with Nikwax and had good results on the event fabric but the active shell was never the same even after rewashing rinsing and reproofing. So what should I do with gore Tex pro to avoid the same result? And do you tumble dry or not? Arctreyx shell if it makes a difference. Cheers
Arcteryx will have your information but it's going to be the same advice probably.
The arctreyx instructions are same as I did last time but it really did not work for the gore active shell. So I was wondering if there are anything else I can do. Or was tye active shell a bit delicate? The gill event jacket is tough as hell and still worked like new after ten years. Sadly left on a train....
