Cleaning disk rotor...
[Closed] Cleaning disk rotors, with what's to hand
23 Users
Brakes sound as if I'm being chased by a flock of irate seagulls and pads are pretty worn. Got new pads ready to go in but need to clean the rotors first as they feel distinctly greasy to the touch.
I'd use meths to clean them if I had any, but I haven't (and I need the bike tonight). What I do have is :
Diesel
White spirit
Can of heavy duty de-greaser
Can of barrel and choke cleaner
Huge variety of domestic cleansing products
Any of the above or just good old soap/washing-up liquid and water?
Posted : 05/07/2013 10:05 am
White spirit is an effective de-greaser. I'd use soap and water to get the main grime off, followed by a wipe down with the white spirit
Posted : 05/07/2013 10:08 am
What about those alcohol wipes, they work pretty well for rotors. 😉
Posted : 05/07/2013 10:12 am
Doesn't white spirit leave an oily film behind?
 cp
white spirit first, then soap and how water to get the residue off.
Acetone if you have any lying around.
Posted : 05/07/2013 10:13 am
BAby Wipes, or take them off and chuck them through the dishwasher
White spirit will leave an oily residue behind
Posted : 05/07/2013 10:14 am
It's frickin oil! Take it nowhere near your brakes! It's not a degreaser, it's a solvent!
Washing up liquid and hot water in a clean sink (i.e. you don't want the remenants of last nights fry up coating them in oil), and rinse in fresh water, anything else will leave a residue.
washing up liquid
Posted : 05/07/2013 10:17 am
Thanks guys. Washing up liquid and hot water it is then.
Posted : 05/07/2013 10:28 am
Fair enough, I use Iso-propyl alcohol myself to clean my rotors as it happens. But white spirit is used as a degreaser in machine shops, just didn't realise it left a thin film behind
Posted : 05/07/2013 10:49 am
White spirits is a degreaser (and a solvent*), a very good one at that. However it is not a very defined mixture so there may be heavier weight molecules left behind - the amount would be negligible.
Warm water and washing up liquid would be my choice. Maybe a green scourer as well.
*Infact it is a solvent for many greases!
Posted : 05/07/2013 10:52 am
hmmmm im having this my self at the minute - about a week ago i suddenly out of no where started getting a squealing front brake, its been silent using the same pads (superstar sintered since ive owned them well over a year ago), all of a sudden its got a squeal on braking, not a major one and it will fade as you brake more, but then comes straight back next braking session
i even put a new set of again superstar sintered in and its doing the same with the new pads! not sure why its suddenly started to do it given the silence on the same pads over 1.5 years
looking at my hope saw tooth rotor (which is about 3 years old?) its got a kind of rust type coating in places that i cant get off with meths, is the rotor buggered? pretty sure its now my rotor that causing the issue as my back brake using the same pads/rotor is still deadly silent throughout!
ive used some muc off brake disc cleaner on the pads and rotor and although it goes at the start of the ride its comes back squealing after a few sessions of braking
shall i give the rotor a rub down with sand paper type stuff? soak it in rubbing alcohol? then to finish some muc off brake disc cleaner?
or shall i sod the sintered off and get some organic to stop the noise?
Posted : 05/07/2013 11:06 am
IPA as mentioned above (not booze) is superb.
Posted : 05/07/2013 11:18 am
ive got some IPA (rubbing alcohol so ill give that a try)
is that not what brake disc cleaner is though?
Posted : 05/07/2013 11:21 am
Give the diesel a try and let us know how you've gotten on.
Most hospitals let you use phones now
Posted : 05/07/2013 11:24 am
Washing up liquid in warm water works ofr my dishes and I'm sure some of them ore more greasy than rotors get.
Posted : 05/07/2013 11:25 am
OW. can you check the disc thickness? Perhaps it is just worn?
Dish scourer is good... I used to buy expensive 3m scotchbrite pads for metal buffing til I discovered you can get what seems to be the exact same grade pad from tesco, 3 for a quid, for cleaning pans.
Posted : 05/07/2013 11:31 am
my hope floating rotor is about 3 years old and had a good life, dont mind replacing it if its worn and thats the cause, theres defintely some wear marks on the rotor braking surface and some strange rust type/scored wear to it to in places
will try with organic pads first as i dont mind running them in summer, if that also fails ill buy a new rotor as ive always had silent brakes with hope floating rotors
seems weird its only just started happening, and my rear one is still fine and silent (using same pads)
Posted : 05/07/2013 11:37 am
Wheel's on fire
Rolling down the road
Best notify my next of kin
This wheel shall explode!
[i](Apologies to Julie Driscoll)[/i]
Posted : 05/07/2013 12:11 pm
Fairy liquid, stop touching them
Kryton, try organic pads, sometimes metal pads get squealy in the dust and dry
Posted : 05/07/2013 12:17 pm
Choke/carb cleaner is a solvent.
I've used it on discs before to degrease them to good effect.
Also excellent for cleaning out gunk filled headsets.
Posted : 05/07/2013 1:05 pm
I use a can of brake and clutch cleaner from the car spares shop sprayed onto a rag or kitchen roll, seems to work well. I think its mainly IPA, though not sure.
Posted : 05/07/2013 1:28 pm
Why would anyone need to clean their rotors?
Posted : 05/07/2013 1:32 pm
White spirit is itself somewhat oily, so whilst it shifts grease it doens't clean to the required cleanliness for brakes.
Brake cleaner has never worked for me. Supposedly it contains something for anti-rusting, maybe it's ok for cars but it seems awful on my bikes - even the Muc Off bike specific one.
Clutch cleaner works brilliantly, but it doens't last long.
Acetone aka nail polish remover is effective but damages some plastics, I'd be wary
Meths is good ime
Rubbing alcohol seems not to be widely available here, surgical spirit is though and that's just methanol and ethanol I think, works well on brakes.
Electronic contact cleaner also works very well indeed, I think it's the same as clutch cleaner though - smells like it.
Soap and water works rather well too, if you agitate it. Also water on its own is quite good, for lightly dirty rotors. On the trails I find a puddle with some fine mud in it and rub it all over the rotors with finger and thumb until it gets squeaky. Works a treat.
DO NOT use a sweetened drink from your camelbak though - the sugar or whatever is in there goes sticky and the brakes will squeal like bastards for ages.
I don't know, but my brakes often benefit from it. I have no idea how they are being contaminated - maybe I have a micro leak in the hose or seal and traces of brake fluid are getting on there.
Posted : 05/07/2013 1:49 pm
Take the rotors off and put them on a hob. You can do the same with the pads depending on type.
Get them pretty hot to burn the oil/grease off. I did the pads till they stopped smoking.
There is one pad compound you have to be careful doing it with. You should find it with a quick Google though!
Posted : 05/07/2013 3:11 pm
Meths or carb cleaner are the best 'usually in the garage or drinks cabinet' options. Although I guess carb cleaner is pretty rare in most households these days.
Tried the MucOff stuff in a fit of professionalism, it was fine but no better than my 99p meths and some cotton wool for the few times a year I clean the rotors.
Posted : 05/07/2013 3:18 pm
I was gonna say!
Personally, I've found Muc-off brake cleaner to be worse than meths, and worse than pretty much anything else. Last can I tried I binned it rather than use it on my brakes. Very scary to apply the levers and have nothing happen.
Posted : 05/07/2013 4:11 pm
