cleaning disk brake...
[Closed] cleaning disk brakes?
9 Users
Evening. ..
Currently my xt brakes sound like a flock of banshees screaming the death of the Hampshire country side...
So what to use to clan them? Mucoff disk cleaner or just give them a wipe over with some ipa???
Posted : 04/08/2013 6:31 pm
Posted : 04/08/2013 6:36 pm
Any branded disk brake cleaner or ipa will do,
May be worth cleaning the pads too or replacing them if they still sequel after that.
Posted : 04/08/2013 6:39 pm
Nice one. Cheers for that.
Posted : 04/08/2013 6:41 pm
Meths will do as well. Use a stiff toothbrush and then really rub the pads and discs hard with a clean rag. Re keying the pads to the discs with a few hard stops will also help.
Posted : 04/08/2013 7:03 pm
Spilt dot fluid over pads and rotor the other day...degreaser and a good clean and rinse then pads washed in fairy liquid and the residue burnt off on the hob
Refitted em and bedded em in and hey presto, no noise
Posted : 04/08/2013 7:11 pm
Recently mine stopped biting so cleaned with iPa and sanded sintered pads. All fine now.
Posted : 04/08/2013 7:51 pm
The water and grit on todays Exmoor Explorer cleaned my rear pads right down to the backplates (they where nearly worn out anyway). 😉
Posted : 04/08/2013 9:19 pm
I thought the common thinking (folklore?) was that auto brake cleaner was bad because it left a film of oil, which is beneficial (reduces squealing?) on the more powerful and hotter disc brakes of cars and motorcycles but not so great on bikes.
Anyway, IPA or bike brake cleaner (which is usually IPA anyway).
Posted : 04/08/2013 11:43 pm
That was some brake eating conditions I finished the last 3 miles with zero front brake and the back brake metal on metal heard a few others at the finish in a similar state.
Posted : 05/08/2013 6:37 am
