Chromoplastics on ...
[Closed] Chromoplastics on Planet X London Road - What size?
2 Users
Hi, I know there are a few people on here who have fitted mudguards to their London Road so was wondering if anyone had fitted Chromoplastics and if so what size? I want to keep tire options open although currently have 35c Land cruisers so keen to fit as big as possible. Do 45s or even 50s fit?
Cheers, Dan
Posted : 04/01/2016 5:46 pm
45s fit fine, over 38c Barlow Passes here.
Posted : 04/01/2016 5:50 pm
Brilliant thanks, hoped they would. Will order some tonight
Posted : 04/01/2016 5:52 pm
I bought the Trekking ones with reflective side strips, front flap, and rear reflector. Mounted the front one using the rear fork bridge hole and you can see below how the front stays fit the fork blade holes.
Clearance with the tyres is enough for roads and gravel. Gets clogged on mud paths though, but this is on 38s. I think 45 is the widest you'll get under the fork.
Posted : 04/01/2016 6:09 pm
Cheers again, will have a look at those too once I've had dinner 🙂
Posted : 04/01/2016 7:06 pm
