chris king bottom b...
[Closed] chris king bottom bracket question
8 Users
i bought a new (to me) frame recently and it came with a perfectly good Chris King BB installed.
however, i want to take it out and install it on another bike i have... no problems there.
when i took the drive side cup off there were no spacers installed... is that normal? (it's a 73mm shell)
I've installed loads of Hope and Shimano BBs, and they've all needed a 2.5mm spacer on the DS during installation.....
should i use one whilst putting it on my other frame?
Posted : 13/03/2015 4:24 pm
Don't think you need spacers on a 73mm shell. I certainly had none on my 26er Trance X.
Posted : 13/03/2015 4:43 pm
 LeeW
Did the original owner remove it for a better chainline? If it was me reusing the BB, I'd use however many spacers owere needed on my new build
Posted : 13/03/2015 4:44 pm
hmmm, good point ref the chain line... i could always ask him, i still have his number...
and cheers Dom, i'll see what the chap i got it from says i think 😉
Posted : 13/03/2015 4:56 pm
Probably this.
But, if you remove a spacer from the drive side to gain a better chainline, would you not have to put it in the non - drive side?
Posted : 13/03/2015 7:29 pm
Usually if you have a 73mm bb one spacer on the drive side is needed, depending on chain line and what set up it was running before ie 1x10 2x10 etc
Posted : 13/03/2015 9:45 pm
 JoeG
[url= http://chrisking.com/tech/tech_PDF ]http://chrisking.com/tech/tech_PDF[/url]
Posted : 14/03/2015 12:03 am
The spacer on a 73mm BB is there to take the place of an E-type mech or similarly mounted chain device (that's why it's drive-side only). If either of those is fitted, you won't need it.
Posted : 14/03/2015 12:06 am
Probably this.
Correct, otherwise you'll have 2.5mm of spare axle, unless as SR says there's an e-type mech or chain guide.
Posted : 14/03/2015 10:21 am
