Chopping out a Seat...
[Closed] Chopping out a Seatstay bridge, sensible?
19 Users
I'm currently hacking about an old steel (kona) MTB frame, it's going to be used as a Road/towpath tourer/commuter/winter road bike.
I'm welding on Disc tabs and grinding off the old (26") canti' mounts, I've also offered up a couple of 700C wheels/rims in the frame and at present it looks like I would be limited to 622x32mm which is adequate but being able to fit something like a 40mm tyre would be nice.
The only thing preventing a bigger tyre being fitted is clashing with the seatstay bridge, part of me is wondering just how essential this element of the frame really is from a structural point of view, and if I can get away with chopping it out to increase clearances... Before I get busy with the angle grinder offer me some reassurance (or not)...
Posted : 17/08/2018 1:13 pm
Kona obviously just put it there because they had a bit of extra material lying around and the welders were bored. The only thing that could possibly go wrong would be the frame cracking and needing to be binned. I say, grind away!
Posted : 17/08/2018 1:18 pm
PP Shans don't have a seat stay bridge, and they're designed to be flung around. If it's just a pub bike, why not?
Posted : 17/08/2018 1:33 pm
 5lab
seatstay bridges were critical when rimbrakes were a big deal - I can't imagine they do a huge amount on a mountain bike being ridden to the pub
Posted : 17/08/2018 1:37 pm
If you are welding on disk tabs, could you not modify and raise the stay bridge a little further up?
While you have the welding kit out and the frame on the bench like.
What Jef said, why not just move it further up?
It probably ads a smidgen of stiffness to the rear triangle so without it the flex might cause something to crack in the seat collar area.  It's only a might though as the seat stays were probably heavier gauge than required in order to deal with the canti brakes.
Posted : 17/08/2018 1:41 pm
Moving it would cause more stress than removing it.
Posted : 17/08/2018 1:54 pm
I'd also think about 650B wheels and tyres instead, would allow you to use bigger volume tyre without upsetting the geo/raising the BB as much. 584 x 38 or 42 should fit within the available space, keeping outside rolling diameter in check but giving more cush. Just a thought...
 cp
I cut out my chainstay bridge on the cx for mud clearance with no ill effects
Posted : 17/08/2018 2:02 pm
Seat stay bridges very useful for:-
mounting rim brakes
mounting mudguards
stopping stays bowing apart under canti brake loads
If you don’t need to do any of that then they aren’t needed.
Posted : 17/08/2018 2:07 pm
Welding it back on a bit further up is 100% more effort than just cutting it out, grinding the tube smooth and re-painting (rattle can) the stay.
This is just going to be a rough and ready mod, nothing fancy and I'm removing the canti bosses too, it's only going to be used on towpaths and roads. Of course having something there to fix a guard to would be beneficial, but that could be done with a simpler plate or other ways.
The extra clearance is really just a "would be nice" rather than a vital need.
I think I'll leave it for now, I'll probably only fit 28mm tyres to start with anyway...
Posted : 17/08/2018 2:22 pm
Wouldn't the stays bow apart under vertical loads also? As in due to the forces from the rider?
Posted : 17/08/2018 3:06 pm
Seems a sad thing to do to a nice old frame for 8mm of tyre, 26" wheels will actually run fine BTW.
The stays don't do mcuh tho, likely OK to do.
Posted : 17/08/2018 3:19 pm
It's only a fire mountain and using it with 700c wheels is the plan to allow for a bit of interchangability with my other bikes.
Posted : 17/08/2018 3:42 pm
Would the seat stay brace also not help to prevent differential shear of the combined seat/chainstays, or is the triangulation of each side sufficient to stop this? I’m just wondering if you’d get more disk brake rub when cornering or leaning th bike to one side.  I feel a need to FE it.
Posted : 17/08/2018 3:47 pm
I think it may well be a bit of a "convention" in that frames have alway had bracing local to the wheel, in road bikes it supported a caliper, on canti/V braked frames it provided some bracing for reaction forces when the brake was applied, and in all instances its a handy place to attach a mudguard...
Like others I also now have an MTB which has "braceless" stays obviously as it is disc only and not intended to have mudguards that makes sense...
Posted : 17/08/2018 6:03 pm
A couple of cable ties should sort it.
Posted : 17/08/2018 6:16 pm
cynic-al   Member
Replace it with a spoon
Yeah, do that.
Posted : 17/08/2018 6:59 pm
I would imagine (IANAE) that the uneven forces from the added disc brake would be the bigger issue. I'd question whether the seatstay bridge would help balance that assymetry...
Posted : 17/08/2018 7:01 pm
Frame builders love seat stay bridges as they hold the rear triangle together when attaching them to the front triangle. I expect the chain stays on a Fire Mountain are pretty beefy, but it still might be worth fitting a brace into the NDS rear triangle to help distribute the stresses.
I knew someone who was an ex-pro XC rider who modded his ex-team, rim-brake race bike by having disc tabs welded to the seat stay without accounting for it being constructed from super-skinny steel tubing. Took his bike to Moab, first ride snapped steatstay, OTB and an expensive visit to hospital
Posted : 17/08/2018 7:21 pm
Yep, I'm planning on doing this, seems to be the accepted wisdom when doing this sort of thing to older frames...
Posted : 17/08/2018 7:40 pm
If it were mine I'd probably chop it out.
Biggest problem you might find is a rusty hole in the seatstays if water has collected in the bridge tube. Had this when doing the same (disc tabs etc) to a friend's Raleigh 853 frame. Brace also had to come off anyway as that had rotted. Just brazed a couple of little oval patches over the stay holes and all has been good for a few years.
Posted : 17/08/2018 8:13 pm
Cut out the seatstay bridge, then use it as the NDS brace.
That way you gain a NDS brace and haven't lost the seatstay bridge - sort of...
Posted : 17/08/2018 10:33 pm
Remove the brace, but put an old brake-booster onto to the v-brake posts. Does the same thing structurally but with way more clearance.
I am not a welder.
Posted : 18/08/2018 8:43 am
