Cheapest tubeless p...
[Closed] Cheapest tubeless presta valves??
2 Users
Wheres cheapest for valves??
Can you just cut some valves off some old tubes if they have removable cores?
Posted : 19/11/2014 6:35 pm
's'wot I do. And I dont even care if they havre removeable cores. I just pop a section of bead off the rim and tip the goo in.
Posted : 19/11/2014 6:42 pm
Thanks.. Perfect use for the Vittoria tubes I have that don't like patches.
Posted : 19/11/2014 6:46 pm
my top tip is to cut the valve out with small patch of inner around it - say 20p deimater sized, and then cut another narrow long piece that's as wide as the rim channel. Put a hole in the narrow piece for the stem to go through and then you theres more material for latex to make a decent seal with.
Posted : 19/11/2014 6:50 pm
