Cheapest Direct Mou...
[Closed] Cheapest Direct Mount SRAM Chainrings?
8 Users
who does cheap direct mount chainrings these days? used absoluteblack oval, but pretty pricey, the sram ones are fairly expensive, i know superstart do cheap narrow/wide but cant seem to find any cheap SRAM direct mount ones?
Posted : 02/03/2016 4:57 pm
Think my 30t could be a Chromag, never had the 32T SRAM one fitted and will probably need a 28t for the Alps
Posted : 02/03/2016 5:01 pm
OneUp, Works, Wolf Tooth, RaceFace all do SRAM ones
Kore just started doing them, ditto Chromag.
Loads of options. None of them are cheap, really - EBay for RaceFace maybe your nly shot at saving a few quid.
Posted : 02/03/2016 5:02 pm
cheers
dont rate the raceface ones, think they were far quicker, and seem to not hold the chain as well either due to the teeth profile not being as long (IMO of course)
will have a look at the others, just seen chromag have the XSYNC license on theirs, and look a bit cheaper than SRAM ones
Posted : 02/03/2016 5:11 pm
 MSP
Sram have started doing some steel direct mount chainrings that are miles cheaper than the alu ones, eg
https://www.rosebikes.de/artikel/sram-x-sync-1-x-11-direct-mount-kettenblatt/aid:859036?gclid=CIfm7pXAossCFaoEwwodSTgPLQ
Posted : 02/03/2016 5:14 pm
yeh saw them a while back, but they dont fit on XX1 cranks, only the lesser entry model i believe 🙂
Posted : 02/03/2016 5:15 pm
As above, steel ones are the cheapest! Last well too. Cheaper in the UK that the Rose link above (unless you want a few of them)
Posted : 02/03/2016 5:16 pm
ok, im sure i read they werent compatible with xx1 cranks? can you confirm ben please?
id be after a 32t steel one if so! i dont mind the marginal weight gain as it will out last the alloy one tenfold
Posted : 02/03/2016 5:20 pm
Oscillate Wildly - Member
cheers
yup pretty much every other brand last longer and works better than the RF n/w rings
fwiw i think chromag & RSP do x-sync but doubt its very cheap
Posted : 02/03/2016 5:22 pm
the race face ones are shite! honestly got 2 chains out of one, before a) it dropped on every rocky descent in sight and b) put a new chain on and it was that worn it just wouldnt mesh at all (pulling at the release point)
get through about 3 or 4 chains on my oval one from AB, but they are expensive, looks like the chromag one is a little cheaper, but dont like all the loud lairy graphics 😳
ps, knew the STEEL sram ones didnt work, they only do a 28t direct mount option that i can see
Posted : 02/03/2016 5:25 pm
I'm selling a brand new 36t works component bb30 £15 posted?
[URL= http://i1311.photobucket.com/albums/s665/Jonathantraverse/A5EA8011-342A-4680-948D-7688DF1F38F9_zps6tuxcos5.jp g" target="_blank">http://i1311.photobucket.com/albums/s665/Jonathantraverse/A5EA8011-342A-4680-948D-7688DF1F38F9_zps6tuxcos5.jp g"/> [/IMG][/URL]
Posted : 02/03/2016 5:31 pm
Now sure how cheap you're looking for but the [url= http://www.workscomponents.co.uk/works-components-32t-sram-oval-gxp-fitment-narrrow-wide-spiderless-chainring-267-p.asp ]Works[/url] one isn't to bad at £25.
Posted : 02/03/2016 7:04 pm
that is cheap fathomer! I could get two for the price of one of the other brands, although the teeth do resemble very much the raceface ones
Posted : 03/03/2016 9:08 am
