Hi all
Just fitted a charger 2.1 rc2 to my Yari and would like to see if there are any base settings you can recommend to help set the fork up.
Many thanks.
Steve
No actual settings to suggest but I’d have all the damping settings on their fastest initially. Set your desired sag first with the airspring - then bounce about gradually slowing the rebound until the bike doesn’t feel like it’s coming back up at you too hard.
At that point I’d go and ride it and see how it is. If the fork is diving a lot then dial in some lsc until you’re happy with it (think there are 18 clicks of lsc). With hsc id leave that wide open to start with - I think there are only 5 clicks of adjustment on this one.
If low speed diving is fine but you’re blasting through the travel in the mid range / towards full travel then you can either use hsc or tokens in the air side of the fork to adjust this out.
Cheers.
Looking forward to getting out on it at the weekend
