Changing wheel bear...
[Closed] Changing wheel bearings.
6 Users
I have slowly but surely been learning how to fix, mend and build up most things on my bike over time. I still have a long way to go but i have recently realised my front pro2 hubs have some play in them and its probably worth getting the bearings replaced.
So in the spirit of doing things myself i looked online. Then promptly decided the wheel was going to the shop.
So, is it actually worth buying the tools and investing my time for what is probably a quick job to a shop?
Posted : 13/08/2013 9:45 am
You don't need the tools to change Hope wheel bearings, but like all jobs like that, they make it easier.
I wouldn't even think of taking my hopes to a shop to have that done, it part of the reason I buy them, and I'm a mechanical numbty
Posted : 13/08/2013 9:49 am
zippy, im a bit of a mechanical numpty which is why youtube is my friend.
I watched a few vids with an array of tools and had that instant thought. NOT FOR ME 🙂
Posted : 13/08/2013 9:53 am
Try [url= http://www.mountainbikerides.co.uk/index.php?option=com_content&view=article&catid=3:wheels&id=5:hope-xc-rear-hub-service&Itemid=9 ]this guide instead[/url], yes it's for a Hope XC hub, but the Pro II is basically the same, just different bearings (and pawls but you know what I mean)
Posted : 13/08/2013 9:57 am
Nice one, Ill give it a bash 😀
What could possibly go wrong.
Posted : 13/08/2013 10:01 am
[url= http://www.bikeradar.com/gear/article/workshop-replacing-the-main-bearings-in-a-hope-pro-ii-21339/ ]Pro II guide[/url] just use sockets that fit the outer race of the bearing instead of the Hope tools, and support the hub with a couple of bits of wood, when needed.
Posted : 13/08/2013 10:02 am
or this one http://www.cyclistno1.co.uk/features/maintenance/hope-pro-ii-rear-hub-service.htm
yes i know it's for the rear but should show how easy it is!
Posted : 13/08/2013 10:03 am
I managed to do front & rear on mine. The front was so easy it's not even funny. Can you hit things with a hammer? You can change those bearings.
The rear should have been easy but the bearings were completely seized to the axles so bigger hammers and some replacement parts were needed.
Posted : 13/08/2013 10:05 am
The tools are a little bit of a red herring. Pro 2s basically need 2 things- things to hit, and things to hit them with. The Hope tools just make things really straightforward but I use sockets, as I have loads of sockets, other folks use wooden drifts, old bearings, etc.
The only thing is, it's got some possibility for screwing up- you can damage the hub if you get a bearing in squint enough (or hammer one out squint enough) and it's also possible to damage hte new bearings as you fit them.
Posted : 13/08/2013 10:07 am
Right, I'm all over this 😀 luckily its my front that has developed the play so I'm not going into the deep end straight away.
Regarding grease. I use Prep m for my turner journal bearings. Is this suitable for regreasing or should i use some other type??
Posted : 13/08/2013 10:10 am
hammer in, hammer out, simples. I did buy the tools as I don't have a socket set.
Posted : 13/08/2013 10:12 am
