Changing press fit ...
[Closed] Changing press fit BB
3 Users
I'm looking to change my cranks to 30mm diameter so need to replace my hope bb which is a hope pf41 to a 30mm what best way of removing the current bb
Posted : 01/12/2019 1:10 pm
Follow the instructions on Hope's website, look under tech support.If you haven't got the installation/removal tools, it'll probably be cheaper to take it to a shop that has.
Posted : 01/12/2019 1:20 pm
You can drift it out either using a taper punch or piece of dowl / wood and a hammer, will just tap out
Or you can buy specific unior or park tool kit to do it.
Posted : 01/12/2019 8:15 pm
Do not try to drift it out, it's threaded together using Hope's specific tools.
Posted : 01/12/2019 8:57 pm
The Hope PF41 BB only consists of two separate bearing and can be drifted out and pressed in. If you have a different BB in currently, some are screwed together but most just tap out.
https://www.chainreactioncycles.com/hope-pf41-press-fit-30mm-bottom-bracket/rp-prod135904
Posted : 01/12/2019 9:34 pm
There are two types of PF41 BB's, i'm assuming he's got the screw together 24mm jobby, not the 30mm press-in bearings as he wants to remove it so he can fit a 30mm crank set.
Posted : 01/12/2019 10:35 pm
