Changing levers bla...
[Closed] Changing levers blades on XT M765 brakes?
3 Users
There is not an obvious way to do this, the pivot appears to be a rivet.
Googling suggests it is possible but possibly quite tricky. Wondered if anyone has succeeded and would you repeat the experiment?
Posted : 01/04/2012 11:16 am
tried it on some SLX's gave up, couldn't get the replacements and LBS reckoned you couldn't.
Cheaper to get a new lever
Posted : 01/04/2012 11:27 am
There is a little grub screw you need to undo. Google BL-M765 EV to find the exploded diagram and you will see what I mean.
Posted : 01/04/2012 1:28 pm
Thanks, off to give it a go then...
Posted : 01/04/2012 1:56 pm
Cheers Mr P, job done.
Posted : 01/04/2012 2:55 pm
