Changing Fork Trave...
[Closed] Changing Fork Travel
5 Users
Just wondering how you know if you can change the travel on a fork, specifically a Reba like this one from 100mm to 120mm:
[url= http://cgi.ebay.co.uk/Rock-Shox-Reba-Team-2009-10-100mm-fork-with-Pushloc_W0QQitemZ300388371470QQcmdZViewItemQQptZUK_sportsleisure_cycling_bikeparts_SR?hash=item45f08acc0e#ht_636wt_1167 ]Reba on ebay[/url]
Can I change these using the internal spacer or are they stuck at 100mm? I'm after some 120mm forks for a Trek EX Fuel.
Cheers,
Mintman
Posted : 22/01/2010 8:18 pm
Some forks you can, some you can't. Most Fox models you can change internal spacers to adjust.
Reba Teams, I'm pretty sure 100mm is the max travel.
Posted : 22/01/2010 9:07 pm
I've converted some 2010 Reba Race's from 100mm to 120mm. They're normal QR versions, not Maxle. The RS website says they're 80/100/120 travel and that the maxle is (just) an option. The travel info is the same for all versions, so they might be worth a shot?
Some people have said if they're OEM you can't change the travel to 120. Don't know if mine were OEM or not, I got them off ebay too. Unless the guy has had them apart to check, you wouldn't lose too much if you had to sell them on if they weren't right.
Posted : 23/01/2010 10:46 am
Reba's usually change in 15mm increments. So they can be 85, 100 or 115mm travel.
Should be able to strip them down, take out the last remaining spacer & they'll be 115.
I've done both aftermarket & OEM forks without problem.
Posted : 23/01/2010 10:51 am
Mintman
I have a pair of 09 reba race that i will be selling . Set at 120mm with poplock in very good cond
put them on new frame 2 weeks ago with new oil and they are to short for it so going to sell erm
looking for £190 posted
will do some pic later if you would like yeh ?
Posted : 23/01/2010 11:10 am
