Changing flat to dr...
[Closed] Changing flat to drop bars
7 Users
I have a hybrid with flat bars and I am converting it to drops for cyclocross use, it is based on mountain bike chainset and bottom bracket, can I put a road compact and external bottom bracket on it or is the bottom bracket shell incompatable, it will only have a double chainset
Posted : 18/05/2011 9:00 am
what frame?
Posted : 18/05/2011 9:31 am
I did something similar with a Road Rat and ended up using my mountain bike cranks with a sort of faux compact double using Middleburn chainrings, one on the middle ring position, one on the outer - 34/48, I think. Shifts okay with a Sora shifter and a lot cheaper than a new crankset and bottom bracket. I found 32/48 was too big a jump for clean shifting btw.
Posted : 18/05/2011 9:36 am
Didn't want to mention the make, its a Marin, an old one though, I only use it for the 3 Peaks but they have changed the rules this year and you can't ride with flats
Posted : 18/05/2011 9:38 am
If the frame is a 68mm BB shell then a road compact chainset will fit. However if the back end of the hybrid is a 135mm spacing and you may find the crank arms are quite close to the chainstays due to the reduced Q factor. It is probably a case of try it and see.
Posted : 18/05/2011 11:15 am
Have you thought about how to sort the brakes, going from flats to drops?
Posted : 18/05/2011 11:16 am
Lots of possible issues, incompatability of:
mtb front mech/sti
mtb front mech/road chainset
brake levers/calipers
BB shell too - tho IIRC Marins are 68 so you'd be OK.
Posted : 18/05/2011 11:20 am
Am using STI levers and frog leg brakes which should be ok
Posted : 18/05/2011 1:13 pm
For the shifters have you considered bar end mounted ones?
I think these generally cope with more extreme ratios than STI as you might have a friction/ratchet option, hence why they still appear on some tourers?
Posted : 18/05/2011 1:24 pm
