Changing a groupset...
[Closed] Changing a groupset bit by bit
6 Users
This is probably a stupid question, but...
I currently have Campag Veloce (10-sp) on my bike, and want to upgrade to 11-sp Potenza or Chorus. The thing is, I can not afford to do an entire groupset replacement at the same time, and besides, I just put on a new standard FSA chain set that I really like and have no need to replace.
So my question is: if I start by replacing my shifters and front and rear derailleurs (plus chain and cassette as well, of course!), can I use the FSA brakes that are on the bike already? Or do I have no choice but to change everything at the same time?
Posted : 01/04/2019 6:55 pm
Depends if the pull ratio of your current brakes is the same. I don't know how you'd find this out. Maybe there are some second hand Campag callipers you can get to squeeze them within your budget?
Posted : 01/04/2019 10:21 pm
It wear is not an issue currently, buy it piecemeal and fit all in one go. Otherwise it is a check to see if brake pull ratios are the same and if the shifter/mech ratio is the same. I can’t add any more detail as modern Campag is a bit unknown to me.
Posted : 02/04/2019 1:04 am
Without looking at prices myself, I suspect that buying all those items individually will quickly add up to nearly the price of a full groupset especially if you factor in selling the unused Campag chainset.
Posted : 02/04/2019 6:43 am
It almost always works out far cheaper to buy the full groupset - places like CRC, Ribble etc will probably have it at knock down prices anyway cos its Campag and no-one buys it.
Get the full groupset on 0% finance, sell the bits you don't want and anything decent from the old groupset then fit it all at once.
Posted : 02/04/2019 8:30 am
Thanks all. I ended up getting brand new Potenza levers, brakes, and front and rear derailleurs for well within my budget. Now I just have to get an 11-speed cassette and chain and all the new cables, and I will be able to assemble.
P.S. I should add, in defence of Campag, that while I totally understand that it is minority kit, it sure isn't easy to find on ebay at a decent price. And when you do, it's not like there's no competition for it.
Posted : 02/04/2019 9:09 am
 aP
Hmm... I've just taken 2012 Chorus 11spd off my CR6/4, but then that'll be of little help to you now.
Posted : 02/04/2019 9:27 am
