So this should be a 5 min job, but I’m seemingly being a numpty and can’t work out how to remove the old cable from the connector nut thing so I can put a new one in. Google has failed me too. I’m in need of STW help….
https://flic.kr/p/2mZvCzP
This is how it is currently…
Sorry, which end is that? Doesn't look like the bikeyoke connector thingy under the post that I remember, unless you've somehow pulled the whole thing out (or they've redesigned it!).
EDIT: Ah, I've found the part now. The cut end is attached in there somehow, is there a tiny allen key hole somewhere?
Undo 33 from 36 then pull out the plunger
@jimmy748 thank you! I had the second diagram you posted but not the first one - I can see how 33 comes off now… Here goes, many thanks!
Success!! Woohoo, thanks Singletrack
