Chamois cream recom...
[Closed] Chamois cream recommendations - help keep my undercarriage tidy
30 Users
I prefer a thicker lotion, got some great stuff made by Overstims in France a few years ago but it's running out and not available in UK.
Tried another brand but it's much sloppier and I'd prefer to avoid that dirty nappy sensation after pulling my shorts up.
Any suggestions?
Posted : 07/06/2016 12:10 pm
Sudocrem works for me.
Posted : 07/06/2016 12:13 pm
Can you just order it direct. Benefits of the EU and all...
https://www.overstims.com/ANTI-CHAFFING-CREAM
Posted : 07/06/2016 12:16 pm
Assos, always
Posted : 07/06/2016 12:19 pm
Massive fan of Morgan Blue soft stuff, but it is 'sloppy'. Don't see it as an issue like, actually prefer it. If you want it harder, then probably Assos or MBs solid stuff.
Posted : 07/06/2016 12:46 pm
I'm currently using [url= http://www.wiggle.co.uk/paceline-products-chamois-butt-r-eurostyle-8oz-1/ ]this[/url], Paceline European Style Butt'r. Quite thick, a little minty and does the job well.
If you can find some Beljum Budder that's was very good too but I believe they've stopped making it.
Posted : 07/06/2016 12:51 pm
Asos is great, Sudocrem if you really like the thick gloop though.
Posted : 07/06/2016 12:52 pm
Assos +1.
Threads over, get some work done!
You had my hopes up there nemesis, but postage to UK doubles the price.
Is Assos thick and does it rub in quick? That's what I like about the Overstims stuff, Sudocrem just smears about and makes a mess doesn't it?
Posted : 07/06/2016 1:04 pm
It sort of melts, rubs in quick and is medicated.
Posted : 07/06/2016 1:07 pm
I'm sold then
Posted : 07/06/2016 1:31 pm
Anyone tried Chapeau chamois cream?
http://www.chapeau.cc/original-menthol-chamois-creams.html
Posted : 07/06/2016 1:51 pm
What price, comfort? 🙂
Posted : 07/06/2016 1:53 pm
I like this
http://www.planetx.co.uk/i/q/HNDANC/docs-all-natural-chamois-cream
Not too sloppy, not too thick.
Posted : 07/06/2016 2:11 pm
Well I am sure it does if you put half a tub on !
It might leave your short pad a bit white, but what does that matter, better than brown 🙄
Posted : 07/06/2016 2:35 pm
Comments like that on the derailed Ramadan thread please 😉
Posted : 07/06/2016 2:48 pm
I have been an Assos man for the last few years. The Chamois Butt'r Euro Style is OK for shorter rides, but the Assos stuff has more staying power for longer rides.
A few weeks ago I bought some of the new Castelli dry lube. First impressions are very good. The biggest thing is that you get none of the slippy sloppy feeling of regular creams, You don't notice it's there at all, but you get no chafing.It's a bit expensive, but you need very little of it relative to other creams.
Posted : 07/06/2016 2:51 pm
Waitrose baby bottom or vaseline.
The latter did the trick for 40 miles this morning
Posted : 07/06/2016 2:58 pm
Coconut cream from savers, slap it on good and thick.
for what type of rides/duration are folks using these products ?
Posted : 07/06/2016 3:01 pm
Currently using some from Chapeau and it seems to work well. Have also used Assos cream as well which was good as well
Posted : 07/06/2016 3:22 pm
Just curious –How much of this gunk are you chaps applying? I might occasionally use some downstairs lube but only a thin application prior to a long ride? I get the impression some of you are really slopping it on every time you pop down the shops on the bike?
Posted : 07/06/2016 3:29 pm
Just a bit for long or hot - or long and hot - rides (fnarr fnarr).
My last tube has pretty much lasted since 2011, to give you an idea.
Posted : 07/06/2016 3:33 pm
Yep, that's me too. 100km+ I'll apply, much less than that and I won't.
Posted : 07/06/2016 3:46 pm
5 years!
In that case, < £25 for the one you know works for you seems like good value 🙂
Posted : 07/06/2016 3:47 pm
Does me for all day rides. £2.50/500g from Sainsbury's.
Not greasy, but may be a bit sloppy for the OP.
Posted : 07/06/2016 4:41 pm
Anything over half an hour. For my morning commute - 45 mins - I just wave my fingers at the pot and apply a tiny amount either side of the perineum.
If I'm doing a couple of hours training I'll use a little more. And for 5/6 hours, I'll be a bit more liberal (a good squeeze of toothpaste maybe, rather than a handful)
The Castelli dry lube stuff seems to require much less, and has excellent 'staying power'.
For big adventures (all day in the saddle) I may take a dab of cream in some foil and apply half way though the day.
Posted : 07/06/2016 7:51 pm
Buttonhole from PX. Mintier than Assos, half the price just as effective.
Posted : 07/06/2016 7:56 pm
Charlie the bikemungers bum butter works really really well pre and post ride silky smooth no rashes and I can't really say anything bad about it it works and smells nice
Posted : 07/06/2016 7:59 pm
 kcal
Morhulin is pretty sticky rather than smeary, works a treat - based on - I think cod liver oil (certainly has a certain whiff). Great for all-day application.
Posted : 07/06/2016 8:02 pm
OK, this might be a silly question, but how is it applied? Do you put it on the chamois or under yourself?
Never used the stuff before, but I want to get a few more miles in on the road.
I'll be looking at all the suggestions in this thread 🙂
Posted : 07/06/2016 9:09 pm
Cream in hand, cup then apply liberally to the under carriage. Avoid Knob, might sting a bit.
Posted : 07/06/2016 9:21 pm
I use cream on any ride of any note, so pretty much whenever I'm wearing bibs. I used to use bike specific stuff, quite liked Endura but afrer a while and perhaps roo many times of not having the real deal to hand I started using whatever was to nearby, often my wifes hand and face cream. So now Palmers Butter or whatever looks quite thick in the Savers £1 for a tub section is my choice. There all much the same,
I apply it liberally on everything bum, creases and right up to the Jon Thomas. I dont see any point in being mincy just slap it on and ride.
Posted : 07/06/2016 9:22 pm
MTB Rob - I use the Chapeau cream and it's as good as the Assos stuff for me, thinner so goes on better whereas the Assos stuff can be a bit hard if it's cold.
Posted : 07/06/2016 9:48 pm
So this isn't the STW cream of choice anymore?
Do the folk that put cream on for every ride possibly like the feeling a bit too much?
Posted : 08/06/2016 6:52 am
Thanks Kryton57, no nonsense! 🙂
Posted : 08/06/2016 7:22 am
 emyr
Got a sample of Bikemonger's Happy Bottom Bum Butter at the Dorset Gravel Dash signon. Forgot to use it. Suffered for a few days after.
3 days of MTBing in last weekend's heatwave, dab of Bum Butter each day, super sweaty but no problems.
Posted : 08/06/2016 7:38 am
I use Assos or those single packets of chamoix butter stuff when on multiday rides, otherwise I do'nt bother. I wear bib shorts all the time and don't feel the need on a regular ride
Posted : 08/06/2016 7:51 am
The Udderly Smooth mostly because a tub is lasting me forever. I had some samples of some rapha stuff which weren't noticably better (I also couldn't buy that as I have their winter embro and mixing the two cans up could be nasty).
Posted : 08/06/2016 7:52 am
I used to use the Udderly cream. I thought there was no way I was paying more for the Assos stuff. Then I tried it. No comparison really. Unless you fill your shorts with it, the Udderly seems to dry out and lose its lubricating properties after a couple of hours.
Posted : 08/06/2016 9:10 am
I used to use the Udderly stuff, but then I believe they reformulated it and include a parabens preservative which lead to me getting a nasty nipsy rash.
Posted : 08/06/2016 9:13 am
Price is good. Is it thick or sloppy?
Posted : 08/06/2016 9:25 am
As to enjoying the feeling a bit too much, probably. I also like using gold bond body powder for non bike pursuits, similar medicated coolness. Neither as good as the feeling when I used to race cyclocross though, that burning leg feeling and the smell was very addictive.
Posted : 08/06/2016 9:29 am
I use the Rapha stuff but only if on 100k + rides or it's very cold and wet or hot.
Posted : 08/06/2016 9:35 am
I used to use it years ago with "real" chammy. I don't seem to feel the need these days with synthetic pads, but then the most I'm out now is 4-5 hours on MTB which isn't the same as sitting all day on a road bike. Or maybe by bum's just like a piece of leather now.
Posted : 08/06/2016 9:46 am
I got some buttonhole on Kryton57's recommendation. Don't think its quite as thick as Assos. It spreads on nicely and has a nice warming sensation. Be careful where you put it though!!. Before I was using anything that was about ie: wifes creams and lotions etc til she pointed out her L'Occitane hand cream is £28.00 a tube 8O. She has nice soft hands though.
Posted : 08/06/2016 10:03 am
You should get her to use her L'Occitane hand cream to massage into your nethers before you go riding. Two birds, one stone.
Posted : 08/06/2016 10:08 am
I see waitrose baby bum stuff mentioned earlier in the thread. I picked some of this up when I forgot my normal assos stuff on my last trip. I've not looked back. Cheap as chips. It's made of olive oil, I think, with a nice vanilla scent. It does the job of anti chaffing very well.
Posted : 08/06/2016 10:48 am
Thanks Zero cool and Milky1980, been using Chapeau Chamois Cream for a long time, it does a the job and I think it is good, but as I not tried many other Chamois Creams was interested to get other opinions.
Interesting you both compared it Assos cream!
Posted : 09/06/2016 7:24 am
I've never used product even riding 100+ miles, however, curiosity has gotten the better of me an I've ordered some assos stuff from CRC.
Not sure how having a minty hole will help my cycling but you never know, could be a revelation.
Posted : 09/06/2016 7:36 am
You can't beat a minty hole.
Posted : 09/06/2016 7:58 am
