Chainstay length.
[Closed] Chainstay length.
11 Users
Short or long? which is better? how does it affect the bike? does it just depend?
Thanks.
Posted : 20/05/2014 1:22 pm
short, easier to get the front end up
long, more stability on steep climbs
current trends seem to favour shorter = better and 1x transmissions have helped a lot with this.
other areas (eg front centre) will have a big effect too so look at a package rather than just one measurement.
Posted : 20/05/2014 1:25 pm
Shorter=more playful, longer=more stable.
So, as with most things on a mountain bike, there is no better, just changing fashion. Recently the fashion has been to keep them short, but no doubt that will change.
Posted : 20/05/2014 1:29 pm
Long enough to fit the wheel in, depends what you want it for and what it's bolted to
Posted : 20/05/2014 1:30 pm
I'm looking at 29er single speeds. Currently riding an inbred. Wondered whether a shorter chain stay would stop the rear wheel losing traction on some climbs.
Posted : 20/05/2014 1:36 pm
For single speeds it's more about where you position body weight and controlling your pedal input when climbing than frame geometry, for me.
traditionally longer seat stays are seen as a good thing for climbing as they stop the front end wandering but your weight will be more on the front wheel as a result so maybe a shorter stay will shift your weight back a bit stood up.
Posted : 20/05/2014 1:40 pm
It 'depends', yes. Shorter = better, we've been there before in about 1987?
Balance is good; extreme numbers to get attention, maybe, maybe not?
Not really, and your CS length will be dictated in 1/2" increments based on your gearing. 32-18 gearing means a common CS of around 440mm, or a really short one at under 430mm (rarer)
Posted : 20/05/2014 1:52 pm
shorter = crapper at climbing, but more fashionable.
longer = crapper at manuals, but better at climbing.
scholarsgate - Member
maybe, but mostly it would just help you fall off backwards on steep climbs.
Posted : 20/05/2014 2:12 pm
[i]shorter = crapper at climbing[/i]
Bollocks.
Posted : 20/05/2014 2:22 pm
Bollocks.
This ^
Posted : 20/05/2014 2:31 pm
Long chainstays = boring bike.
(having owned one that had long chainstays - old Giant Reign.)
Posted : 20/05/2014 2:38 pm
Oy mate, your chainstays are too long.
Posted : 20/05/2014 3:03 pm
 JCL
Yeah that guy needs a longer stem to put more weight on the front 🙄
Anything under 430mm is crap on a medium unless you like large spring rate differentials and the unpredictable pitch stability that brings. 440mm is pretty good for a medium and +/- 10mm on small/large sizes is about right.
Posted : 20/05/2014 3:22 pm
