Chainrings - help a...
[Closed] Chainrings - help an oddball mate of mine!
9 Users
He runs a commuter with a nexus and wants high gearing. He has worn out his alloy chainring - a big lad 100 kilos of pure POWA!
I cannot find him a steel unramped 42 tooth 4 bolt 104 bcd chainring - any clues?
Thanks guys - he thinks I am the bike bits oracle so help me to keep up my image and help him and his bike destroying ways!
Posted : 12/07/2020 10:46 am
Not steel I'm afraid, but the Aladins cave of SJS only lists one 104bcd 42t, so that may make your choice easier!
https://www.sjscycles.co.uk/chainrings/32-thorn-104mm-bcd-4-arm-reversible-single-chainring-332-inch-black/
The Thorn one looks durable and is reversible.
Maybe OnOne or Surly might have something?
Posted : 12/07/2020 11:05 am
Just use a cheap Shimano 8spd ring
Posted : 12/07/2020 11:08 am
surly are bound to do one but it'll cost 3xShimano
Posted : 12/07/2020 11:22 am
Change the size of the sprocket to suit whatever ring you can find?
Posted : 12/07/2020 11:24 am
he is on the smallest sprocket and a 42 chainring is the biggest that fits!
Posted : 12/07/2020 11:26 am
If he can wait a while then Aliexpress might be good cheap:
https://www.aliexpress.com/item/4000076560458.html?spm=a2g0o.productlist.0.0.7ef0419fOo00np&algo_pvid=47e37662-f1d3-43b5-9168-7b79fbe0ff30&algo_expid=47e37662-f1d3-43b5-9168-7b79fbe0ff30-6&btsid=0b0a187915945499795351714edf93&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Oh I see the 'unramped' spec req now.
There's plenty of 42t+ NW 104bcd alu chainrings on there cheap - get a couple - can't see steel.
Posted : 12/07/2020 11:34 am
Think you'll struggle to meet all those requirements. Ramped might be your only option
https://smile.amazon.co.uk/dp/B004SHE5WK
Posted : 12/07/2020 12:04 pm
Ta folks.
He went for the SJS one as above - he couldn't wait for you to come up with more options 🙂
Posted : 12/07/2020 12:06 pm
If he doesn’t like it then I’ve a Renthal 41t unramped 104/4, or I can recommend Projection Components https://www.projection-components.co.uk/drivetrain-166-c.asp for stainless chainrings.
Posted : 12/07/2020 2:30 pm
ta!
Posted : 12/07/2020 2:34 pm
more and more 5 bolt as some gravel / CX and even non-race road bikes go over to 1x setups. Worth upgrading and futureproofing?
Posted : 12/07/2020 3:40 pm
