Chainring spacers -...
[Closed] Chainring spacers - where from?
7 Users
I'm after some black washers to adjust my chain line,
The must be black and only 1 or 2mm
Anyone know where I can get some from?
Posted : 30/11/2014 8:31 am
Why do you need to adjust your chainline in the first place?
Posted : 30/11/2014 9:16 am
Just Googled "chainring spacer" and got pages of hits. They all appear to be silver. Time for a black marker pen.
Posted : 30/11/2014 9:34 am
Washers is the obvious answer, if or where you could get black ones I'm not sure.
But even on single speed, 1 or 2mm probably won't make much difference to any problem you may be having. Look at 2mm on a ruler, over the length of a chainstay that's 3/4 of f*** all angular difference.
You running a single ring on a double chainset?
Wheels Manufacturing do suitably sized spacers - 1.2mm ones are part no WM0031 and 2mm are WM0032. Madison do them, so any shop can order on the codes above.
Posted : 30/11/2014 10:45 am
oldnpastit I was looking at the wear on my narrow wide chainring and the narrow teeth are more worn on the outside compared to the inside, I wanted to move the chainring in a little bit to see if it made a different on the teeth wear.
sillyoldman I'm running a single Narrow Wide chainring on a Saint double crankset, the chainring is mounted in the 'middle' position, thanks for the part numbers though.
Posted : 30/11/2014 6:09 pm
I have just fitted some 5mm spacers to my xt frank running 1x10.
Made a bit of difference to chainline but be careful as you may need longer 'female' chainring bolts.
Posted : 30/11/2014 6:39 pm
Honest question, as I've never tried 1x?? and narrow-wide. Can't you turn them round as there's not ramps and pins to worry about?
Posted : 30/11/2014 6:55 pm
tthew, I was going to turn it round but the one I have has one side with a recess for the female part of the chain bolt.
Posted : 30/11/2014 7:51 pm
