chainring help
[Closed] chainring help
6 Users
Hi,
Following a couple of chain graunchings, Ive knackered my large chainring on my Suntour CW15-XCM chainset (double - 22t, 36t - 64/104 bcd). Shimano acera 9-speed cassette.
As a bit of a novice Im struggling with finding a decent replacement from the seeingly vast array out there. Am I right that as long as i get the same tooth count, speed and bcd that I can use any make or is it not that simple? I realise I cant use one specific to a 1x with wide/narrow teeth.
e.g blackspire offer one that matches my stats but says its for a shimano xtr fc m980.....would this work or are there other things I need to look out for. Is there anything cheaper and similarly compatible or is this a typical price?
wiggle link
Posted : 13/10/2019 10:46 am
This is where your LBS comes to the rescue.
Sometimes good advice is worth paying for when you buy stuff.
Posted : 13/10/2019 10:56 am
Has to have same number of arms and not be assymetric as well.
Posted : 13/10/2019 11:12 am
You can pick up an entire replacement Suntour crankset (including rings) for 35 quid on Tredz.
Would have thought you could get a 10sp Shimano chainring with the right boltcircle to work for slightly less than that Blackspire one.
Posted : 13/10/2019 11:15 am
I've gotta slightly used slx 665 36t 104bcd 9speed you can have.
Posted : 14/10/2019 9:58 am
This is where your LBS STW comes to the rescue
ftfy
There's no need to spend the Blackspire money. I used to buy all my chainrings on eBay.
But you're right - long as the rings are the same speed & BDC they'll fit.
SLX chainset would be better though 🙂
Posted : 14/10/2019 10:08 am
