I'm looking to replace my chainring - currently SRAM 32T Eagle X Sync 2. Just want to check that my understanding is right in that I need 6mm offset version (not 3mm) as I'm running non-boost - Calibre Bossnut vintage 2020.
Also, if I never went for a direct SRAM replacement are there any other good suggestions.
Hard to beat a steel x sync 2 ring for £20 or less. Nothing else will retain the chain any better.
All you’d be buying is something lighter or more bling looking really.
@joebristol I guess you're right. I don't have an urgent need to replace mine but will do so soon if I can find one. Is the 6mm offset for non-boost is right?
6mm offset is non boost in Sram yes
