Chainring bolts are...
[Closed] Chainring bolts are too long...
12 Users
Having gone super tough and changed my 30t front chainring for a 32t, my chainring bolts are too long.
The 30t ring had threaded holes, but the 32t needs both halves of the chainring bolt.
Is there a spacer i could/should use? or do i need different bolts?
thanks
Beener
Posted : 01/10/2018 11:24 pm
Try track bolts, they should do the job.
Posted : 01/10/2018 11:26 pm
Just short chainring bolts, get them online easy enough these days.
Raceface ones £2.49 a set at wiggle/crc
Posted : 02/10/2018 1:07 am
See if you can find the ones that use a hex head on the back instead off the awful slotted ones. Like these.
https://www.worldwidecyclery.com/collections/chainring-bolts/products/wolf-tooth-components-set-of-5-chainring-bolts-for-1x-use-dual-hex-fittings-blue#
Posted : 02/10/2018 3:19 am
Just drill a 10mm hole in some scrap wood and slot the female ends in and file them.
Drill size might be wrong...
Posted : 02/10/2018 6:38 am
Singlespeed chainring bolts?
Posted : 02/10/2018 6:45 am
You get single speed chainring bolts which are shorter, Race Face do tabs (just spacers) to allow you  to use double chainring bolts with a single ring.
Posted : 02/10/2018 8:58 am
big file and a vice. You probably only need 2-3mm taken off. make sure you are able to chase the threads out afterwards
Posted : 02/10/2018 9:47 am
i shall try the filing idea...it appeals to my sense of thrift!
thanks all
Posted : 02/10/2018 11:42 pm
LOL £3 and you're going to spend hours modifying bolts.... crazy.
Posted : 03/10/2018 8:02 am
 JAG
It’ll take as long to file the bolts as find and order what you need online.
I’ve assumed you have a file and a vice to hand 🙂
Posted : 03/10/2018 8:14 am
I'd use 2mm spacers (i.e. https://www.sjscycles.co.uk/chainsets/alloy-chainring-spacers-20-mm-for-middle-outer-ring-pack-of-5 ) to get the same chainline as the 30T.
Posted : 03/10/2018 8:47 am
I ruined a ride with spacers, snapped one of the bolts and bent the chainring riding up San Marino.
Just get the proper bolts
Posted : 03/10/2018 10:13 am
ok...proper bolts it is.
Im an idiot
Posted : 03/10/2018 12:11 pm
