Chainring bolt size...
[Closed] Chainring bolt size help!
2 Users
So im planning to convert to 1x10 and ive bought a raceface 30t wide narrow ring and these [url= http://www.chainreactioncycles.com/e-thirteen-single-ring-bolt-set/rp-prod66378 ]bolts[/url].
Question is, will these work on my deore triple crank in the middle position? If not, which bolts will.
Im all confuuuused haha
Thank you.
Posted : 20/01/2014 12:11 pm
yes.
But they were £5 less fron Charlie the bike monger 🙂
Posted : 20/01/2014 12:16 pm
Ive just found the compatibility chart for the 30t ring and it says the required size is 8.5mm and the ones i ordered are 6mm. Oops. Looks like they will be sent back.
Posted : 20/01/2014 12:22 pm
It dpends on the chainring you've got. Some of the Raceface seem to have a moulding with a larger thread, the 5mm are for what I class as 'standard' single rings, I have noticed some are a bit different.
Posted : 20/01/2014 12:25 pm
Got the ring fitted Friday. Can confirm the required bolts for the 30t is 8.5mm. This is good because they are used on a standard triple crankset! So I can send those bolts back and save a tenner!
The ring look lovely and going 1x10 has reduced the clutter significantly.
Posted : 28/01/2014 1:52 pm
