chainline on 1x10
[Closed] chainline on 1x10
2 Users
Just changed from 1x9 to 1x10 and can't get highest gear (smallest cog) to stay in gear.
Using an old Shimano XT triple on a Ragley Big Wig - checked end stop screws etc etc
Had no problems running 1x9 - is it possible the thinner chain and different cassette has revealed a chainline problem?
Can't see with the naked eye anything obvious but interested to know if its a known problem and how to remedy.
cheers
Jim
Posted : 24/03/2015 7:39 am
Should be no reason why it shouldn't work, running a 2x10 on a triple crankset without issue, and numerous ppl use triple with single ring. Tired mech (though I imagine you using a new one).. B screw or chain length issue maybe? You have used the std/normal spacer setup for the crankset, not tried to adjust the chainline by changing the BB spacers around?
Posted : 24/03/2015 9:06 am
Might take another look at chain length.
It is a new mech so don't think that's the issue.
Crankset is set up as standard, same as it was when running 1x9 - so other than changing the mech and cassette nothing else has changed...
cheers
Posted : 24/03/2015 12:24 pm
