chain sizing - your...
[Closed] chain sizing - your method ?
9 Users
2 + bash - how do YOU size your chain ?
Posted : 29/06/2009 11:30 am
big-big @ longest c'stay (if suspended) + 1
Posted : 29/06/2009 11:32 am
hardtail - big to big with a little bit of spare in the mech springs
sus - as above with a couple of extra links for supension movement (suppose you could take out the shock & check it's enough but I never have)
Posted : 29/06/2009 11:33 am
longest c'stay will be at full extension, no compression, i assume , or is it frame specific ?
Posted : 29/06/2009 11:34 am
big-big +2 for me
Posted : 29/06/2009 11:35 am
What cynic-al said.
Big big plus 2.
I always size mine with the spring removed and shock at full compression, don't bother threading chain through the mech when sizing, as that's what the extra links are for.
Posted : 29/06/2009 11:38 am
I presume you mean a new chain on a new bike - othersie I hand both on a nail and trim to size of last chain (i.e. count links) coz its never sooo stretched as to get confusing 😉
Posted : 29/06/2009 11:39 am
so many variants !
Posted : 29/06/2009 11:40 am
Big-big +2 here too, as read in thew SRAM instructions which come with my chains.
Posted : 29/06/2009 11:53 am
Foxy, thats because chains don't actually stretch, they just wear out inside the links I believe - so they should be the same length/number of links.
Posted : 29/06/2009 1:12 pm
I'm clearly the monkey here because I fit the chain with a speed link then remove the "right" number and reattach the speedlink.
Posted : 29/06/2009 1:35 pm
brassneck: chains don't actually stretch, they just wear out inside the links I believe - so they should be the same length/number of links
you can argue semantics if you wish in terms of stretch vs wear, but they DO get longer (that's how chain-checkers work)
atlaz: I'm clearly the monkey here because I fit the chain with a speed link then remove the "right" number and reattach the speedlink
The discussion is about how you determine the "right" number - I'd guess we nearly all use powerlinks or similar
Posted : 29/06/2009 1:45 pm
well when you hang them up they are sl longer thats what I was pointing out. I am aware the link plates dont "stretch" but the overall length changes beause the pivots wear and become thinner. Thanks for pointing out what chain stretch is brassneck though 😉
Posted : 29/06/2009 2:03 pm
