Chain lube used by ...
[Closed] Chain lube used by the works for the Dakar KTM team - is it too much for MTB?
9 Users
If this can survive Dakar conditions why not use it for MTB chains? Too much stiction?
Motorex Adventure Chain Lube https://www.dirtbikexpress.co.uk/workshop__and__tools/motocross_oils/motorex_motocross_oils/motorex_adventure_chain_lube_-_500ml_spray?msclkid=066705c4136a1e5abc2265c1fd0ee085
Posted : 18/01/2021 8:28 pm
No idea but I’ve just learned about o-ring and x-ring chains as a result of looking!
Posted : 18/01/2021 10:53 pm
Definitely too glutinous for MTB, motorcycle spray oil is designed to be 'anti fling'
Posted : 18/01/2021 11:05 pm
BTW O & X chains negate the need to soak in putoline wax and allow riveting rather than split links.
Posted : 18/01/2021 11:08 pm
Gosh. Lubricants for chains. What will people think of next?
https://www.putoline.com/en/catalogue/maintenance_chain-lubricants/
Posted : 19/01/2021 7:42 am
By contrast I used to use putoline wax on my o ring chains and they were also held together with a split link.😂
You can rivet most chains not just o rings.🙂
Posted : 19/01/2021 7:48 am
Copy & pasting?
Posted : 19/01/2021 7:52 am
I did some of the Dakar routes (not racing, just following the same routes at our own pace) In preparation we removed all the lube from the chains so they didn't pick up any sand / grit. For the 2 weeks we were riding round, the chains were fine and stayed clean. Following the trip I seem to recall I continued to use mine for a year or two more.
One section we did took the pros 4hrs, it took us about 12hrs and at the time we were racing in the UK pretty much every weekend.
Posted : 19/01/2021 8:20 am
Thanks all for the sensible answers. @Trimix - riding the routes must have been some experience! You rode with no lube at all? I can see the logic, even the Woburn sand grinds like mad but surprised you got away with it?
Posted : 19/01/2021 9:05 am
It's a standard approach for CX races on sandy courses too. No lube > the risk of picking up sand
Posted : 19/01/2021 11:36 am
No lube in sand, but remember X ring & O ring chains are somewhat tougher than yer average mtb chain... FYI _ I ran a std (not HD) chain on my trials motos & for several years just used a spray of WD40. Chains lasted one year regardless. In Sussex Mud & no Putoline involved!!
Posted : 19/01/2021 11:39 am
I used to use motorbike lubes on mine with far better results than MTB specific stuff many years back (Castrol wax was my favourite, but was discontinued, now using White Lightning clean ride), never found the too thick/anti fling argument to be an issue.
Posted : 19/01/2021 4:26 pm
<You can rivet most chains not just o rings.🙂>
You can, but not easy to remove to dunk in wax though is it ?????<
X ring with scotoiler is the answer
Posted : 19/01/2021 5:19 pm
