Hi,
I've just converted my double and bash chain rings to a 1x.
I've installed a Oneup style iscg 05 top guide (Not actually Oneup a knock off), but the guide isn't far enough over to cover the chain. It is way too far in,
Is this abnormal, what have I screwed up?
Cheers,
Alex
There are spacers to nudge out the guide on the OneUp 😉
I'd say it was a good 5mm too far in. Got washers, but washers and bolts not lomg enough. Get more / longer?
Spacer on driveside of bb? Or have you installed the ring in the outside position?
Definitely in the middle position. There is a drive side spacer, but that's always been there.
What does your chainline measure? IIRC, somewhere between 47-50mm for 1x, although Sheldon Brown will know.
