chain guide bolt ru...
[Closed] chain guide bolt rubbing
2 Users
I am sure this has been asked before but here goes.
I have a 2010 Trek Remedy with old ISCG tabs and just been trying to fit a Gaumt Dual chain device. Seems to be a lot of rubbing between granny ring bolts and chain device bolts.
What is the best way to solve?
cheers
Posted : 29/07/2010 5:31 pm
I've solved a similar problem on a different bike/device by removing the washers from the chain device bolts.
Maybe worth a look?
Posted : 29/07/2010 7:26 pm
Thanks, bolts removed and still rubbing 🙁
I am reckoning on 2 choices being to file ISCG tabs down slightly or add an extra 1mm bottom bracket spacer which hopefully won't mess with chainline too much.
Posted : 30/07/2010 6:37 am
