Chain Dropping
[Closed] Chain Dropping
7 Users
I'm currently running XT drivechain (2 X 10 speed setup) with TA Specialites 38/26T rings. My chain seems to fall off a helluva lot more than when I had the standard 42/32/24 setup. It's not terrible but I do seem to drop the chain at least once per ride. I've just bought a clutch rear mech (not fitted yet). Are there any chain devices that can assist furter for a 38/26 double setup? I haven't got the legs for a 1 x 10 LOL.
Cheers.
Posted : 15/06/2013 7:38 pm
Does it drop when changing front rings, or just under pedalling?
Posted : 15/06/2013 7:44 pm
You might find that the clutch mech sorts it.
Posted : 15/06/2013 7:45 pm
Changing front rings Dan. Yes I'm hoping the clutch mech works some magic - chain device would be belt and braces.
Posted : 16/06/2013 9:36 am
just a thought but I trust you moved the front mech down a little when you changed the rings? Mrs BS runs this exact same set up and reports no issues.
Posted : 16/06/2013 9:47 am
Sounds like a front mech setup issue.
Posted : 16/06/2013 12:40 pm
Cheers guys. Any chain devices for doubles?
Posted : 19/06/2013 7:16 pm
Ive had a gamut chain device with the aluminium bash on my five. Not dropped a chain once.
On my new 1x10 im hoping the clutch mech alone will do the job.
Posted : 19/06/2013 7:18 pm
I don't have a double chain device, but a mate has a blackspire stinger on his and it works fine.
Posted : 19/06/2013 7:21 pm
Agree most likely front mech set up, moving it down will probably help. Also, your biggest ring has gone from 42T to 38T, can you shorten the chain a little?
Edit: Front mech set up - move down as the biggest ring is lower now, but also check your stoppers as you now have less rings so the mech might be moving over too far.
Posted : 19/06/2013 7:23 pm
+1 blackspire stinger. As mentioned drop the front mech so the cage tracks the outer ring with a 1mm gap and ensure you've wound in the limiting screws to avoid overshooting the selected chainring.
HTH
Kev
Posted : 19/06/2013 7:26 pm
Brilliant - I'll check up on all that. Any reccommendations on the ultimate tough durable chainrings for double that still shift well?
Posted : 19/06/2013 7:33 pm
