I'm trying to figure out which chain device is suitable for my bike. Can anyone help?
It's a 2012 Trek Remedy 9 with 42/32/24t front chainrings and it has 03 ISCG mounts.
I was thinking something like this - http://www.wiggle.co.uk/hope-chain-guide-iscg-mount/
Looks nice and simple but before I spend £40 I thought i'd see if anyone could confirm it will fit?
Thanks,
Lewis
No, you'd need something that works with a triple chainring set-up. That chainguide (and most chainguides) are for single chainring.
That 1 won't work in my opinion as you will still have your front mech. And that one is to kind of take the place of front mech
i would've suggested a blackspire stinger but it only works up to a max size of 40t
maybe try one of these instead...
http://www.evanscycles.com/products/bionicon/cguide-v02-ec040588
These work well:
[url= http://cdn.mos.bikeradar.com/images/bikes-and-gear/components/chain-guide/1334326143264-jmdx8kzsia1p-399-75.jp g" target="_blank">http://cdn.mos.bikeradar.com/images/bikes-and-gear/components/chain-guide/1334326143264-jmdx8kzsia1p-399-75.jp g"/> [/img][/url]
Compatible with single, double and triple chainring setups. Quiet and it works.
Yup, I reckon Bionicon or similar is the answer
Thanks for the help everyone. I'll go with the simple bionicon setup.
I was hoping the XTR Shadow mech would stop chain slap but there's plenty of paint chips that say otherwise!
Inner tube round chainstay?
Or sticky velcro...
I found the plastic guide-tube wore very quickly in the Peak - maybe the grit - also check online for fitting instructions and use three rather than two zip-ties and bear in mind you need to lengthen the chain slightly to compensate for the extra distortion in the chain path. It's not the toughest thing out there, but it's very light and does okay ime.
Some thing like this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=18092
Its the Shadow [b]Plus[/b] version of Shimano rear mechs that have the clutch to stop chain slap.
The Shadow (non plus) is simply designed to stay more in board and less likely to get rock strikes.
Sorry I meant shadow plus. It's got the clutch and you can feel the difference but it appears not to be strong enough to stop chain slap.
Have you tried adjusting the clutch strength?[url= http://www.bikeradar.com/mtb/gear/article/trail-tech-how-to-adjust-a-shimano-shadow-plus-rear-derailleur--36461/ ]use this guide[/url]
or check chain length is correct. If everything is fine then I think a Bionicon style chain device is the way forward.
