Chain Device - stup...
[Closed] Chain Device - stupid question
4 Users
I have a chain device on my Lapierre Spicy. It came fitted when new, I took it off initially but I've recently put it back on.
The 'cotton-reel' type guide wheel which the chain rides over the top of, should that rotate or should it remain fixed ?
Seems that it remains fixed at the moment, wonder if I just have it done up too tight.
What do we think ? Should it be allowed to rotate or should it be fixed ?
Ta
Posted : 14/10/2014 3:44 am
I've never seen one fixed.
Posted : 14/10/2014 4:12 am
depends... what is the make of the device? How tight did you do it up?
Posted : 14/10/2014 4:17 am
It should rotate. Did you take it apart? Check you've not lost a little washer that goes against the bearing 'sleeve' and gives the wheel clearance from the backplate.
Some lower wheel bearings are machined with a protruding step that provides clearance, others use a washer. You may well have over tightened it.
Posted : 14/10/2014 5:13 am
Thanks all.
Can't remember the make of the device, but I put it back on as it was set up when it was new. I didn't tighten the roller myself it was that way when it was new. Anyhow, have loosened the nut a little and now it rotates, although it does by hand at least, not sure whether the friction of the chain is enough to turn it or not.
Posted : 18/10/2014 7:15 pm
