Chafing from knee p...
[Closed] Chafing from knee pads - any solutions?
13 Users
SWMBO is getting a rubbed spot on her knee from her 661 knee pads (just on one side though). There doesn't seem to be anything obvious like a seam of anything. A knee warmer under neath so it can move against her skin seems like a good idea but it also sounds a bit hot for the summer. Any other bright ideas?
Posted : 09/04/2012 1:08 pm
tried barrier cream already?
Posted : 09/04/2012 1:09 pm
What pads? The knee/shin pads with the 3 straps around the calf and one above the knee?
I had these and they always chafed - didn't matter what I did to them.
In the end I replaced them for a different pad and tried them on before buying to make sure they felt better.
I think some pads suit peoples shapes better than others.....
Posted : 09/04/2012 1:11 pm
I have the same problem with my knee & shin pads there Fox ones I think, anyway I wear stretchy knee badage thingies or 3/4 bibs to prevent rubbing, TBO I hardly ever wear them these days.
bum butter/arse lard or similar
Posted : 09/04/2012 1:12 pm
chakaping - not yet, is that something to get from a pharmacy?
Posted : 09/04/2012 1:13 pm
Are they on the right knee? My Kyle Straits look identical but if I have them on the wrong side one chafes. The straps goes from the inside outwards.
btw, they are just the knee pad (Kyle?).
Posted : 09/04/2012 1:15 pm
Yes, but think it's similar to the arselard (Assos Cream) mentioned above - which is available from bikey shops too.
Posted : 09/04/2012 1:23 pm
perfect, well try a combo of my Assos cream and a compression bandage thingy. Thanks all.
Posted : 09/04/2012 2:50 pm
Do you wash them regularly?
Posted : 09/04/2012 3:09 pm
When the knee pads are on, they shouldnt be pulled tight along the length of your leg (if you get me!) the bottom strap should be coupled up above your calf muscle so that the back of the pad doesnt rub on the knee cap.
Posted : 09/04/2012 5:46 pm
Could be bobbles - I shaved the bobbles off the inside of my 661 kyle straits which worked. I think the bobbles have been caused by regular washing. They are on their third season and have been machine washed after every ride because I am not a mink.
The end of my straps point inwards on the correct leg which is different to above.
Posted : 09/04/2012 6:08 pm
Bodyglide.
Posted : 09/04/2012 6:11 pm
I have a very good solution to this(which you already mentioned in your post)
I always use a pair of Endura knee warmers under my pads. They do not get hot,and actually help to wick sweat well. Stops all chafing and easily washable. The wicking effect is like a base layer so they definitely don't feel any hotter than just pads alone, and as the skin surface is dryer doesn't get chaffed.
Posted : 09/04/2012 6:12 pm
A healthy dollop of Sudacrem on each knee sorts that out without the need for any excess wraps/bandages etc.
Posted : 09/04/2012 6:21 pm
Vaseline is a cheap option
Posted : 09/04/2012 6:33 pm
