New axle and end caps fitted to my old hub to improve bearing life.
Pop the wheel back in the frame and 9n spinning the wheel, I've scuffed the floating rotor spider and the inside of the post mount.
Seems the new end cap is 0.55mm shorter.
Do I
A. Shim washer between axle and frame
B. Try and find someone who can make a 12x15x0.6 washer to go under the end cap.
C. File down the post mount on my carbon frame.
D. Switch to a fixed rotor?
Are both of the new end caps the same length?
Can't put the old end cap back on as it's specific to the new axle.
Drive side arrangement is the same on both.
washer
Risk with a washer is I lose it every time I take the wheel out.
Some shim washers are on their way though.
What nickc says
What's the best glue for that?
What’s the best glue for that?
awaits someone recommending a multi thousand pound tig welder.
But as nickc non floating rotor.
But a fixed rotor won't match the pretty floating rotor on the front 😉
