Any clues on how to get a new bracket for one of these; Cateye TL-LD1100 LED Rear Light.
I have had two of these over the years and the brackets have gone MIA somehow. They have been the best lights I have had over the years and running on batteries, having a couple of spares in the bag meant I was going to make it home ok. I used them when I was commuting 20 miles a day.
Zyro-Fisher are showing stock for virtually all of the Cateye brackets, so just about any bike shop should be able to order one for you, and even get it sent direct to you if needed.
Cheers, Are all Cateye brackets the same? Any way I could lash something up?
I always end up with the other problem, find loads of random light brackets in the tool box and no idea what lights they are for...
Yes. It’s why I recommend cateye lights. The mounting options make so much sense.
They made saddle rail brackets years before anyone else. They also have seatpost, seatstay, rack. All the same square fitting for all past lights. The exception is their LED strips that fix with a band to the seatpost. They make an adaptor for that too which I also have.
