Following on from my other thread about the lefty forks, I want to swap the headset cups around and have the taller cup at the bottom to slacken the head angle a tad.
Was just about to try the cup remover but it doesn't clear
the bearings which are tight in there and don't want to 'push' out.
BUT I have a thought, as the bb30 cups are bonded into the frame would the headset cups be also?
If not how do I get the bearings out before it's hammer time again..?
[img]
[/img]
[img]
[/img]
Thanks
Cups are bonded. Bearing should tap out with light tappy tap taps.
Bugger, that's ****ed that plane then.....
Cheers.
