Carbon frame repair...
[Closed] Carbon frame repair?
16 Users
Unlucky rear mech strike cracked my 5 month old frame around the drop-out/mech hanger area. Intense haven’t said “no warranty replacement” yet, but if they do, I’ve got 2optiond:
Buy, crash/replacement rear triangle £600
Or
Have it repaired.
I’m totally inexperienced re, carbon frame repair, so I’d appreciate anyone’s opinions/advice.
[url= https://i.postimg.cc/tgf5n3kh/9-BAEA088-A266-4-EAA-9166-7-FB0-E0-B1-F67-F.jp g" target="_blank">https://i.postimg.cc/tgf5n3kh/9-BAEA088-A266-4-EAA-9166-7-FB0-E0-B1-F67-F.jp g"/> [/img][/url]
Posted : 12/02/2019 12:31 pm
If the repair is free do that. Most good frame repair places would easily fix that. Even if you had to pay for the repair it would be significantly cheaper than £600.....
Posted : 12/02/2019 1:05 pm
Might be worth asking here...
http://www.carbonfibresolutions.co.uk/
Posted : 12/02/2019 1:07 pm
Rob Hayles at Recarb is worth a dropping a line to:
https://twitter.com/re_carb?lang=en
I think I'm right in saying that the drop-out areas of carbon frames are actually dense, injection moulded parts rather than laminated fabrications like the rest of the frame, so it'll maybe be trickier to fix than a crack in other areas, but it's definitely worth some exploratory e-mails.
Posted : 12/02/2019 1:45 pm
Have a word with Carbon Bike Repair.
Posted : 12/02/2019 1:55 pm
What's happened? The hanger has rotated rearwards and cracked open the frame at the point where it is shaped to keep the hanger locate in its correct alignment?
I had similar on a v2 genius but it broke off the part of yours that is hanging on. I recreated the missing piece in place with epoxy and shaped with a file/dremmel. In your case, it's still there so I'd simply epoxy the fractured carbon piece back in place and use a small clamp/heat shrink tape to apply pressure to close it all back up as the epoxy cures.
Looks cosmetic to me but I absolutely appreciate the pain of seeing it not perfect.
Posted : 12/02/2019 2:15 pm
Would second Rob Hayles - repaired mine and a mates frame and both immaculate. He will also paint to match existing decals if wanted, and V reasonable on price too.
Posted : 12/02/2019 3:27 pm
That's solid material so an easy fix with a suitable repair compound - pretty easy DIY repair job IMO:
1. Rub it back to the bare material, clean off with solvent wipes
2. Use the hanger as a former with some release film to stop the repair sticking to it;
3. Let the repair compound set solid
4. Dremel or similar to clean it all up, polish up with wet and dry
Use this stuff: Carbon Repair Filler
Posted : 12/02/2019 6:44 pm
Used them via insurance and they were expensive, slow and made an obvious parts mistake.
But the work was good.
Posted : 12/02/2019 6:46 pm
Well, that certainly gives me a bunch of options. Thankyou all for your help/ideas. Intense UK have passed it on to the US to see if they’ll consider warranty. I’ll keep you updated.
Posted : 12/02/2019 9:04 pm
As with others above I would break out the two-part resin glue and stick it back together. There's nothing there that compromises the strength of the frame.
Posted : 13/02/2019 9:40 am
Few mates have used them, quality of work is very very good.
Posted : 13/02/2019 10:44 am
 StuF
These guys seem to do a good job if you're near Derby
www.carboncyclerepairs.co.uk
Posted : 13/02/2019 10:51 am
Again, a second vote for Target Composites - top work
Posted : 13/02/2019 12:05 pm
Update:
Sent Intense UK an email/photos. New rear triangle on the way FOC.
Well happy.
Can’t fault that for customer service eh?
Many thanks for your advice; I did message some of the repair guys, with no response as yet, but all good in the end (if it doesn’t arrive in shards after the ferry journey)
Posted : 13/02/2019 10:48 pm
I'd fix that one and keep the new one as a spare I think.
Glad you got it sorted though.
Posted : 13/02/2019 11:20 pm
I’d fix that one and keep the new one as a spare I think.
^^Second that^^
Probably Worth having a pristine rear end for when you flog it on...
Posted : 14/02/2019 12:04 am
They want it back unfortunately. Don’t think I’ll sell this one, it’ll probably see me out 😂
Posted : 14/02/2019 7:37 am
Good to hear about good CS.
Posted : 14/02/2019 9:58 am
Good showing from intense
Posted : 14/02/2019 11:19 am
